0 Gave up and made a bigger fuel tank (see pic)
0 Poweraythor alternator conversion
0 Which cams ?
Last Post: gusm2
0 The White Bike is the Right Bike Thread.
Last Post: A Seabee
0 need service information for my '71 Ironheqad
0 Torque Cones
0 Throttle Cable Adjustment Question
Last Post: Model H
0 Stator wire hot!
Last Post: oldboy
Last Post: Lowe175
0 Happy Birthday 'jzink0883'
0 will not start
Last Post: 01rk
Last Post: sprink
0 For Sale: 2012 XR1200X
Last Post: joes95bobber
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
6 1997 Sportster S putting +4 front shocks??
0 Wet sumping?
0 Some oil issues!
0 Marshwood Vale, 17th June 2019
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
nightster wheels
Old 28th March 2011
madrider's Avatar
madrider madrider is offline
Sportster/Buell Model: XL883R
madrider will become famous soon enoughmadrider will become famous soon enoughmadrider will become famous soon enoughmadrider will become famous soon enoughmadrider will become famous soon enoughmadrider will become famous soon enoughmadrider will become famous soon enough
Default Double disk brake on Nightster wheels
Hello,
I am thinking of putting the Nightster wheels on my 883R, and I was wondering if the Nightster front wheel will let me install my right side brake disk on it...
Would really appreciate some help.
Thanks a lot in advance
WHEN YOU TELL THE TRUTH, YOU DON'T HAVE TO REMEMBER ANYTHING
Old 28th March 2011
bighit4u32's Avatar
bighit4u32 bighit4u32 is offline
bighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nicebighit4u32 is just really nice
You will not be able to just bolt the rotor on and go. The Nightster hub has no threaded holes on the right side. It is pretty easy to drill and tap the hub for the holes you need though. That's what I did with mine when I converted it to dual disc.
Old 28th March 2011
madrider's Avatar
Thanks a lot for your answer.
Would you have any pics of what you did?
Anything would help
Old 28th March 2011
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
I would be very careful here....I know BigHit did it if his is the thread I am thinking of....but just drilling tapping the hub does not ensure that the bolt pattern is concentric to the hub / axle (ie...they both share the same center point).
How far can you be off without causing balancing issues?....I don't know.
I think if I were to do this I would take it to a machine shop to be done....JMO
Cosmo
Old 28th March 2011
madrider's Avatar
Thanks Cosmo, of course I am going to get it done at a shop... but what are the exact instructions I must give them? Or will they know for sure a t a place where they are used to deal with Harleys...?
Old 28th March 2011
A good machine shop will not care if it is harley or huffy parts. You could just take the wheel all by itself since it is drilled and tapped on the one side of the hub....although giving them the rotor gives them one more part to measure. They'll just measure the bolt pattern and transpose that to the hub when they set the wheel/hub into the machine.
You can help them out too a little by telling them what size tap they'll need. If you have the HD parts manual it lists the bolt sizes in there. If you don't...I can get that info later tonight when I get back to mine.
Old 28th March 2011
madrider's Avatar
Yes please, I would appreciate.
Thanks a lot Cosmo
Old 28th March 2011
Unbalanced's Avatar
Unbalanced Unbalanced is offline
Unbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really nice
Does the Nightster wheel not have a centering flange on the hub like many of the others do? I don't remember...
2008 XL1200N Olive/black
Old 28th March 2011
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
This is an easy job with a drill press using the disc as a drilling guide.
Old 28th March 2011
beanerblank's Avatar
beanerblank beanerblank is offline
Sportster/Buell Model: iron 1200
beanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura about
I'm not sure but I don't think there is a tab on the right side to mount a caliper onto the forks.
