0 Who's still riding???
Last Post: bplinson
0 Stabliser Tie-link 16232-04
Last Post: Vohnsen
0 Top End Not Oiling
Last Post: Vanmor
0 Winter Sucks
0 Her indoors
0 Big Bore '03 883R :)
Last Post: t120r
Last Post: drumbrake
Last Post: Jarlaxle
Last Post: T_worth
Last Post: Bama Lee XLC
0 Shipping woes
0 In Tank Oil Filter?
0 Valve guide replacement SOP
Last Post: NHPS
0 04 Battery Cover on a 95
Last Post: F1J1
Last Post: sltm1
Last Post: Jarlaxle
0 What oil temp do you run
Last Post: JKKO
efi, efi sportster, fuel line, fuel tank
Old 18th March 2012
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Default Removing EFI fuel tank (How-To Video)
There was a thread a short while ago asking about removing the tank off an EFI bike. It's one of those things that once you do, you won't look at the directions the second time. But, for someone that has never done it, it can be intimidating I suppose. So, I made a video to show how quick and easy removing the tank is. There's really no reason not to remove the tank if it makes what you are doing easier.
A couple things to consider:
  • I am demonstrating this on a 2007 1200R. I think it's the same basic procedure for all EFI bikes. I think the 2010+ bikes might have a bit different electrical connection and fuse panel. The bikes with single seats will obviously be a bit different in removing the seat.
  • The manual says to empty the tank first. I've never emptied the tank. Who is right? I personally think it's more unsafe to figure out how to siphon off the gas then just leave it in there. Even a full 3.3 gallon tank is only going to weigh ~25 lbs. A half full tank much lighter, but you do need to be careful with fuel sloshing around. Chose your own poison.
  • While I show "purging" the fuel system by running it dry, I almost never actually do it. I figured it's best to show the "more right" way.
  • I'm not saying my way is the right way and it's certainly not the only way. Do what works for you.
If you hurt your bike or yourself following my demonstration...only blame yourself for following a guy folks call Screw Loose.
Removing the tank:
2007 Sportster Fuel Tank Removal - YouTube
Installing the tank:
2007 Sportster Fuel Tank - YouTube
FSM lists the following torque specs:
Fuel tank mounting screw 15-20 ft-lbs 20.4-27.1 Nm
IMPORTANT!! - The Factory Service Manual is very clear about this! Gasoline can kill you. It is dangerous and explosive. After reading the manual, I'm pretty sure most people that do this will die. Please read your FSM for further important information.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 18th March 2012
883_dave's Avatar
883_dave 883_dave is offline
883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about883_dave has a spectacular aura about
Thanks for the great videos! I will have to do this procedure at some point, now I know exactly how to do it.
Old 18th March 2012
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: FXDL
Other Motorcycle Year: 2014
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
Wow, I never thought of using the battery cover for a tool tray.
Old 18th March 2012
joesporty's Avatar
joesporty joesporty is offline
Sportster/Buell Model: xl 883
Other Motorcycle Model: kz750
Other Motorcycle Year: 1976
joesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant future
Nice tutorial dan..
SMOKEY BURNOUT MASTER OF THE WORLD!!!!!
08 XL883;HAMMER 1250,Heavy breather,Rinehart 2-1, Power Vision,Ebc floating rotor,XR1200 Nissin caliper,1200R Mastery cylinder,RK shocks,1in tank lift,wire tuck,crossroads fork brace,low rise drag bars int.wired,Goodridge Ss line,Chrome valve stem covers, and a few top secret parts..:smoke
Old 18th March 2012
Thanks guys. I know it's not the most riveting thing to watch, but if it helps a couple people I guess it's good enough.
It's portable and always with you when working on the bike.
It makes a very handy tool and small parts tray. I probably use it a little too much and have several times had it overflowing with stuff.
Old 19th March 2012
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Funny....I have this written up myself as I did it for another XLF member a while back....but the video was much better than what I did. Great job again Dan.
The only difference I had was disconnecting the negative battery terminal. I know 99.9999% of the time that pulling the maxifuse will be all you need but pulling the maxifuse doesn't disrupt power to the entire bike....only removing the negative battery cable does. The bike's starter still has power going to it directly from the battery and is grounded. This is one reason that during most installation instructions for parts they tell you to remove the negative battery cable from the ground stud.
Cosmo
Old 19th March 2012
Yeah, I agree pulling the negative battery cable would be the safest. But, not even the manual suggests it. And, 99% of the time I'm too lazy to pull the Maxi-fuse or even purge the fuel line. (Amazing I've lived this long.) But, I do understand the risk and wouldn't discourage someone from doing it if it made them feel better.
Do you recommend emptying the tank? Curious how many people do that. And I wonder how they manage to do it safely with things commonly found around the house/garage.
Old 19th March 2012
Brad's Avatar
Brad Brad is offline
Senior Master Bolter Oner
Sportster/Buell Year: None
I've had my tank of a few times and have NEVER emptied it. But I did heed the warnings of others about it shifting and I was careful. No issues to date...
Old 19th March 2012
Yeah, I've never emptied mine, except when I swapped tanks. But, I'm sure that wasn't the safest thing I've ever done either.
It's never seemed bad to me, but it is worth being careful (dropping a tank would suck). Of course, I have the 3.3 tank, perhaps with the goliath 4.5 tank (or whatever they are) it might be more of a problem.
Old 19th March 2012
Lud's Avatar
Lud Lud is offline
Sportster/Buell Model: 08 1200N
Other Motorcycle Model: GS1150 (x2)
Lud is just really niceLud is just really niceLud is just really niceLud is just really niceLud is just really niceLud is just really niceLud is just really niceLud is just really niceLud is just really niceLud is just really niceLud is just really nice
Nearly 30 years of messing with bikes .. I've never emptied a tank to take it off ... nor taken the battery out (unless it needed to come out for a reason)
HD litigation paranoia.. or maybe their bike are more prone to blow up ?
Just use some common sense - sure some folks still have it out there - n if they dont then they maybe shouldnt be messing with it in the 1st place
That said ..... GREAT VIDEO !!
