Last Post: Hogwylde
0 In Tank Oil Filter?
Last Post: sltm1
Last Post: maverick31210
Last Post: 83ironman
0 How many helmets?
5 Jiffy Standing
0 Winter reading........
0 New H-D Fully Adjustable Piggy Back Shocks And Fully Adjustable Fork Kit
14 DEAR Harley Davidson,
5 Oil pump pressure
0 Is this 1200R worth $4500?
Last Post: longride
0 Bushing alignment
0 Who's still riding???
Last Post: 1977iron
Last Post: kmul
0 THE Trainspotting Thread
0 Big Bore '03 883R :)
hillclimber (69), burtondl2 (51), Cet (49), hagar71 (48), ShaneWolfe (47), grizdiesel (42), Confused89 (34), RAIDER0372 (33), spamer80 (33), svwannabe
Old 29th January 2008
MacAttack's Avatar
MacAttack MacAttack is offline
Sportster/Buell Model #2: Wouldn't that be nice!
Sportster/Buell Year #2: 1957
Other Motorcycle Model: Kawasaki Concours 14
Other Motorcycle Year: 2014
MacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really nice
07 1200R - yes, stumbles a bit when cold, occasionally dies. Most of the time it just skips a beat about 30 seconds after startup.
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
Thanks for responding, it'll be great to show this thread to the dealer and hopefully get it off to corp HD too.
Old 31st January 2008
uofkis1st uofkis1st is offline
Sportster/Buell Year: 07
uofkis1st is an unknown quantity at this point
Default Warm or Cold
Ours (2007 1200C) stumbles about 30 seconds after start-up, no matter what the temp. is outside, or whether or not the bike is garaged, or sitting in a 110 degree parking lot. It has only died twice during these stumbles, most of the time it almost dies, then catches. After that it doesn't usually do it. I've been meaning to make an appointment for it, but just haven't gotten around to it yet.
SPURS-DarkRider's Avatar
SPURS-DarkRider SPURS-DarkRider is offline
Sportster/Buell Model: 1200XLC
SPURS-DarkRider is an unknown quantity at this point
07 1200XLC here, still breaking it in, just barely 500 miles on it. Im glad i saw this topic, because today as i was leaving work about 30 seconds into my ride home, i felt and heard the engine go silent then start up again, just for a single beat and it freaked me out, first time it ever happened to me. After reading these posts, i realized i didnt let the bike idle for a minute or so before taking off, i just goosed it, im gonna pay attention next time to see if it does it after warming up a little.
whittlebeast's Avatar
Other Motorcycle Year: 2008
This is easy. Check the part number on the bottom of the fuel pump plate. Lay on the floor looking up on the shifter side of the bike with a flashlight. There is a white tag on a metal plate under the tank. If the number ends in an A or a B you need a service bulletin done. It has to do with a leaking pressure regulator. Just describe the issue to the dealer and mention that there is a service bulletin. Your EFI will need about 200 miles to dial back in after this fix.
Hope this helps
AW
timmii timmii is offline
Sportster/Buell Model: 1200r
timmii is an unknown quantity at this point
I've had my bike die on me while idling in neutral... after a thirty minute ride! It's just plain embarrassing shifting to neutral while glidding to a stop at a light, than having to restart it at the light.
But putting a couple thousand miles on it and a high flow A/C and rerouting the breather away from the intake (I don't know why they designed it to spit oil into the intake, that just makes stumbling 10x worse) solved that problem for me.
danonator's Avatar
danonator danonator is offline
danonator is on a distinguished roaddanonator is on a distinguished roaddanonator is on a distinguished roaddanonator is on a distinguished roaddanonator is on a distinguished road
Mine stumbles also about 30 or so seconds after startup.
Heck, I almost dropped the bike once when it happened going into a turn.
If there is a service fix for this I want it!
Danonator
jimmyp's Avatar
jimmyp jimmyp is offline
Sportster/Buell Model: xl1200N
Sportster/Buell Year: 08
jimmyp is an unknown quantity at this point
my bike has almost 200mi on it and has been stumbling in the 1st minute or so until warm..
XL50 XL50 is offline
Sportster/Buell Model: XL50 #872
XL50 has disabled reputation
My XL 50 (#872) seems to do it when the temp is below 60
linkin5's Avatar
linkin5 linkin5 is offline
Other Motorcycle Model: Honda XL 125
Other Motorcycle Year: 1982
linkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nice
I don't know if all bikes that stumble when cold are gonna have the fuel pump issue. I haven't checked my tag yet to see if I have the bad one yet, I don't think I do as I get good gas mileage and poor mileage was another symptom of the bad fuel pumps. But I do have the cold stumble and it has died on take off once due to this, and I will now check the lable on my fuel pump to see if I have an affected one.
