0 Battery reversed, bike dead
Last Post: rugger2
0 Innovative motorsports 3918
10 howdy from australia
Last Post: 73HEAD
0 1991 frame/engine original ground locations
0 Rocksett
Last Post: Gone_Shootin
0 EZY Pull for '77 XLCR
0 Jumping and rocking at around 3K rpm
0 GPS Speedo?
5 How do you Wash your Bike?
0 Bike lost power,back fired and stalled
Last Post: zack74
0 A Mad Lad on a Blast
Last Post: Hornsmith
0 Robbie's uncomfortable seat theory
Last Post: MacSporty02
0 Question for RB racing exhaust guys/gals
0 true length of after market brake cable
Last Post: don_don465
0 Cams exhaust note
0 Resistor vs Copper plug wires?
0 Show your bike next to a train
0 1985 XLX Ironhead with Hi-4N Ignition - Spark cuts out at 3500 rpm
0 Oil in air cleaner
Last Post: denguy
0 I guess I'm back
Last Post: Veeflys
0 Ride Report 2019 Black Hills, Grand Teton Mtns., Rocky Mountain Ntl. Park
2 Add your Biker Joke Here...
0 bands or O rings
Last Post: ken883/1200
0 Sundowner seat positioning
0 fuse corrosion
Last Post: jazzman
Old 2nd December 2012
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Default Chain Inspection Cover And Gasket Changed In '09
The rubber primary chain inspection cover gasket # 34986-04 was replaced in '09 by a metal and paper gasket # 34990-08.
At the same time the chain inspection cover itself was changed:
Chrome # 34761-04 by # 34761-04A.
Polished # 34993-04 by # 34993-04A.
Black # 34794-05 by # 34794-05A.
Apparently, the only difference with the new covers is that they are thicker, to go with the new thinner gaskets. The new covers come with the gasket.
There are several threads about this; here are a few of them:
My '06 has obsolete parts. WTF???
First issue with the Nightster that wasn't my fault...
Primary inspection cover gasket
Torque for primary chain inspection cover screws
Folkie
South East England Riders
motorend's Avatar
motorend motorend is online now
Senior Master Bike Builder
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2019
Other Motorcycle Model: N/A
Other Motorcycle Year: N/A
motorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond repute
Don't know about the old ones, but the new ones will leak if not replaced when removing the cover. Ask me how I know.
Old 15th May 2013
RollTideRoadster RollTideRoadster is offline
RollTideRoadster is an unknown quantity at this point
Default great to know!
Good to know, i was noticing the other day that i had some leaking coming from the inspection cover so this is definitely going to save me a headache when i get to fixing it! Thanks.
Old 2nd November 2016
Nibelungen's Avatar
Master Bike Builder
I beg your pardon but i have not understand...
Then when you remove the primary inspection cover on 09 up bike... you have to buy in advance not only the gasket but the cover as well (the gasket work only if purchased like a set)
Is it that right?
Thanks in advance and have a good day
rainbows from other worlds have colours that i don't know
Folkie's Avatar
Brass Nut
No, just buy the gasket. Or you could get the old style gasket if you prefer.
Nibelungen's Avatar
Master Bike Builder
Ok
Understood
The only difference is that the rubber gasket fit all the new inspection cover types... while the rigid one have to be specific to each of them
Thank you very much indeed
Old 15th April 2019
motorend's Avatar
I just went to the dealer today to grab some gaskets for my first service. They handed me a rubber inspection cover gasket for my 19' Iron. I had to ask when they changed them as my 09' had a metal one. Then they took it back and handed me the metal one. Are they still metal from 09 onwards?
Old 15th April 2019
Folkie's Avatar
Brass Nut
Originally Posted by motorend View Post
They are still metal from 09?
I don't know about 'still'. They were rubber from '04 to '08, then changed to metal and paper in '09, as described in post # 1. They have remained the same from '09 onwards.
Old 15th April 2019
motorend's Avatar
Thanks!
