0 Poll: What weight fork oil do you use?
Last Post: rezchug
0 Happy Birthday 'jzink0883'
Last Post: Lowe175
0 Marshwood Vale, 17th June 2019
0 Wet sumping?
0 Been Sitting For 5-10 years; Starts, But Dies
Last Post: Feskerlars
0 Front brake is terrible
Last Post: Hopper
0 Poweraythor alternator conversion
Last Post: saddlebagrail
0 2014 swingarm axle in earlier rubber mount
Last Post: jazzman
0 Does anyone run the Machinist Mike “hydro clutch?” If so how do you like it?
Last Post: Rolli
0 Gave up and made a bigger fuel tank (see pic)
0 Which cams ?
Last Post: gusm2
0 The White Bike is the Right Bike Thread.
Last Post: A Seabee
0 need service information for my '71 Ironheqad
0 Torque Cones
0 Throttle Cable Adjustment Question
Last Post: Model H
0 Stator wire hot!
Last Post: oldboy
0 will not start
Last Post: 01rk
Last Post: sprink
0 For Sale: 2012 XR1200X
Last Post: joes95bobber
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
Old 29th December 2014
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Default HDLAN: CAN Bus
This us what HD say the benefits of the CAN Bus wiring are, which were introduced on the 2014 Spοrtsters. This is actually taken from the 2012 Model Year Technical Changes document, as relating to Dynas, but it's the same as for the 2014+ Spοrtsters.
HDLAN Based Electrical System
  • New hand controls
  • Body Control Module
  • ABS and security option
  • Expanded diagnostics
Electrical System
Anti-Lock Braking System (ABS) option.
Sealed hand control switches with new functions.
  • Use HDLAN (CAN) bus technology
  • Trip function selection control moved to hand controls
  • Hazard light control moved to hand controls
Body Control Module (BCM).
  • Replaces most fuses and relays and TSM or HSFM
  • Eliminates high current loads on ignition and other switches
  • Reduces wire gauge and harness bundle size
  • Permits the use of LED tսrn sіgnals without extra module
  • Integrates security system and all lighting system functions
Body Control Module
Automatic solid state short circuit protection eliminates the need for most fuses and relays while reducing wire mass and wire count.
Incorporates all functionality of current TSM / TSSM including turn signal control, tip-over shut-down; clutch / neutral interlock; security system.
BCM directly controls; Horn, Head Light, Stаrter Sοlenoid, P&A Power.
Additionally Spοrtsters get keyless ignition.
Folkie
South East England Riders
Folkie's Avatar
Brass Nut
Not mentioned there (although it applies), but mentioned in the 2014 MY Technical Changes for Spοrtsters:
One key feature added is the new speedometer with the ability to display gear position and RPM on the LCD display.
Old 26th October 2016
Nibelungen's Avatar
Master Bike Builder
I wonder what it is like... i mean the RPM on the LCD display... one thing is to have a real tach (like yours if i'm not wrong...)... another is to look in a little display a value of RPM always changing...
sooner i will know
rainbows from other worlds have colours that i don't know
Old 27th October 2016
Folkie's Avatar
Brass Nut
It not at all the same as a proper tach with a needle. I had one like that (the rpm in the odometer window) on a Dуna.
Having the speed as a digital read out works well though. It doesn't change as much, or as quickly, as the rpm. I do think that the combined digital speedo and analogue tach is the best of both worlds.
