0 900 dual carb front head
0 hi from anchorage AK
Last Post: charles907
0 The good and the bad
Last Post: seajay
Last Post: Four Speed
0 Air Filter Soaks With Gas
Last Post: 93sportsXLH
0 Forum problems???
0 Buell lightning
0 2 into 1 exhaust build
Last Post: cazz1000
0 Project Strociek
Last Post: Yakcm2
0 WTF Happened
Last Post: Yakcm2
Last Post: Steamboat_Willy
0 08 Nightster No Start
0 Have you ever bought Viagra or any other drug....
Last Post: jammantoo
Last Post: LLOYD883
0 Nightster suspension upgrade (RK). Who has em?
Last Post: SportyHD
5 Do you feel you pay too much for Motorcycle Insurance?
Last Post: Eric Von Zipper
0 Sportster in custom softail frame
Old 26th November 2016
Nagrom69 Nagrom69 is offline
Sportster/Buell Model: Forty eight
Sportster/Buell Year: 2015
Nagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really niceNagrom69 is just really nice
Default Indicator / warning lights not working.
Hi all here I am again.
Ther warning lights under the clock are not working?
The neutral light is but it's very faint and I've noticed in the dark it flashes
When I put the indicator on.
I've checked the connection under the tank.
Every else electrical seems to be working fine although I did have to charge a flat battery yesterday.
I need to be pointed in the right direction .
I went through a large puddle which soaked me and the bike???
Murgatroy's Avatar
Murgatroy Murgatroy is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2016
Murgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to all
If your battery was dead, and the lights are not working I would assume something in the charging circuit would be to blame. It could possibly be the stator or regulator going bad. If it is still under warranty a trip to the dealer might be in order.
sportsterdoc's Avatar
+1 on all points
What was battery voltage when indicator lights were dim?
LED lights have a threshold voltage
I've charged the battery. Rode it today, same that bank of lights under the clock not working .
I will check the battery voltage tomorrow . Looks like a short, like when you see brake lights on a car flash the indicators . I don't know.
I will go to the stealershio but try to avoid if possible.
Could it be the clock ??? The water must of soaked that bad.
Is there a test for the stator , regulator ????)
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
Warranty?
Let the dealership shoot the trouble.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
There are tests for stator and regulator, but unless battery voltage is an issue, testing is not necessary.
Why did you have to charge the battery?
I was fitting a new tank. Ignition on and off a few times . Never had a problem before and I use the bike everyday. Just thought it was the cold weather .
Old 27th November 2016
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Check your grounds, including the one on the back of the primary casing.
Folkie
South East England Riders
Here's the Sportsterpedia section on Voltages and Grounds - Read carefully, take the voltage readings and check all the grounds...
http://sportsterpedia.com/doku.php/h...place_to_start
__o~~o__
IXL2Relax
Reference the XLForum Sportsterpedia
A collection of technical information & advice
