0 2017 Headlight in 1991?
Last Post: vt883
0 WTB 67698-81D Headlight Assembly
Last Post: vt883
0 My Patriot Defender Knock-Off
0 New Sporty in Dallas, TX
0 Sportsterpedia Progress
4 Scared for my rod bearings after cam removal...
Last Post: farmall
5 WTB / ISO: Mid Controls for Frame-Mount Evo (2001 in my case)
Last Post: racemoto
0 exhaust or cams?
0 Bendix / Zenith questions
Last Post: farmall
0 Ohlins sell to Tenneco
Last Post: Reverend G
5 WTB / ISO: Riser, relatively low handle bars, speedometer mount
Last Post: racemoto
Last Post: Scott
0 35mm showa damper seal rings???
0 Cutting drag pipes to use OEM type mufflers...
Last Post: DirtyHarry68
5 Jiffy Standing
5 Eye Protection When Riding?
Last Post: clif02
0 Harley-Davidson Sportster: Merging The Modern With The Timeless
Last Post: Caustic Dick
0 New handlebar wiring harness 81XLH?
Last Post: owlsplace
0 If you could only have one bike, would it be a Sporster?
Last Post: clif02
0 Wire gauge for solenoid
Last Post: LenC
0 Ceramic Coating My Paint
RLAnderson (58), boomer (53), ESCOBAR (47), davenjeip (46), BLOODYKNUCKLES (43), Shudabenz (40), Sporre96, 071200low (35)
Old 25th July 2018
Chrisnyc Chrisnyc is offline
Sportster/Buell Year: 2015
Chrisnyc is an unknown quantity at this point
Default Help with a new noise, 15 Iron 883
I bought the bike brand new in 2015 and about a week ago parked it because I was coming from work and heard a weird new sound. Though the clutch spring plate went bad (they looked new) and changed it to a Eagle1 performance clutch. I’m still having the same noise when the bike revs passed 2500rpm. It does it in all gears and neutral. I checked the chain tention and it’s good at 1/2 cold play. Checked the exhaust bracket, drive belt tention and anything that can come loose and vibrate and nothing. Here’s a video I took, any help is greatly appreciated. Oh and the bike has been well maintained, all maintenance done with HD synthetic oils and what not. Mods are V&H pipes, Hammer intake, and power vision map, the bike has 16,000 miles now and I do all the work my self.
https://youtu.be/ExU9O-M3A7Y
Old 25th July 2018
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
I'm having a hard time telling much in the video (laptop speakers aren't the best). But, my guess is that it might be the primary chain. I recommend adjusting the chain with the bike warmed up and while it's running. Leave the inspection cover on, just turn the adjustment screw a little either way and see if the sound changes. You'll hear the chain slap if too loose and a gear whine when too tight. Many of us find it's the best way adjust the primary chain tension.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 30th July 2018
well, been adjusting the chain with no improvement at all. thinking of tearing down the primary and just pull the clutch basket and the stator cover to investigate in there and make sure everything is ok
Old 31st July 2018
Forgot to mention, it only starts making the noise when hot. only when accelerated and it does not matter if its in gear or neutral, the noise is there after about 2200 rpms
Old 31st July 2018
BKB's Avatar
BKB BKB is offline
If you go into the primary, make sure the nut on the end of the crank is torqued to spec. They've been known to loosen & cause a rattle when not under load.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
Old 3rd August 2018
Ok so found the culprit, and had nothing to do with the primary or engine. DAMN V&H shot shots mounting bracket broke after two years on the bike. Now the question, should I weld or just get a new one? I’ll post a pic once I get to my pc
Old 3rd August 2018
BKB's Avatar
BKB BKB is offline
Weld it with a reinforcement at the weak point. A new one will have the same weak point as the one that broke & you'll just have to do it again. I had the stock crossover pipe/bracket break on mine, right at the weld behind the rear muffler port. It was still under warranty, less than 2 years old, so H-D put on a new one for me. The new one broke at the same weld, less than 2 years later. I welded the original one back together, with a piece of angle iron as a brace, across the cracked weld & it's been on there for more than 5 years.
Old 4th August 2018
Wish I knew how to post a pic to show you. But I will weld it back together since I can't find a replacement one anywhere on the net. This thing is a solid mount with no welds in it but Ill take your advice and reinforce it where it broke. Its crazy the amount of vibration our sporties produce to break a piece of metal so thick.
Old 13th October 2018
Blackhound2 Blackhound2 is offline
Sportster/Buell Model: xl1200n
Blackhound2 is an unknown quantity at this point
Hello Chris, I have the same noise. Nothing to find! Chain/ clutch everithing is oke.
Other oil in use nothing helps. A little more oil in the system and this also not clear the noise.
Greetings Blackhound.
Old 14th October 2018
Get your self a long screwdriver, I bought a set in Harbour freight for like 4 bucks. And put the tip on a screw close to the place you hear the noise coming from and place your ear on top of the handle, it will act as a stethoscope and help pinpoint where the noise is coming from. Also check all heat shields, belt covers, lisence plate holder, or anything that might come loose or has a chance to break. Hope it helps. Mine was the exhaust mount broke and I just welded it back together.
