0 .551 Cams in an EFI 1200
Last Post: EL in NH
0 What jets should i buy? [88 1200]
0 What would you ask the Sportster Engineers/Designers?
0 Sundowner seat positioning
0 I guess I'm back
Last Post: A Seabee
0 Right Hand fork leg 45922-00
Last Post: bimbo
0 Oil in air cleaner
0 Front brake is terrible
Last Post: randy3934
0 Question for RB racing exhaust guys/gals
Last Post: BWP 5p
0 '89 Sportster 1200 Chopper
0 Tightening clutch basket nut (left hand)
Last Post: canoli
0 Wet sumping?
0 Who Runs Turn Signals?
Last Post: Len PA
0 Should I buy a Sportster??
Last Post: Hopalong48
Last Post: pdavis5160
0 Exhaust - Generic questions
Last Post: canoli
3 Ironhead Pictures Thread
Last Post: A Seabee
0 Progress
Last Post: mickey t
0 GPS Speedo?
0 Rutt's Hut Old Bike Night tonight
Last Post: Len PA
0 Grounded
0 74 XLCH - a revival
Last Post: Bow only
longhair (65), Ozarkster (62), Monstermile (50), killswitch (50), yu69lorenzo (50), ChrisAF (49), Ingemar (48), Omega (44), bald_bueller (43), BEHIND BARS (42)
Old 24th September 2018
Nibelungen's Avatar
Master Bike Builder
Originally Posted by jammantoo View Post
I have run several EVO sportsters up over 100,000. it is an engine that is a great bike engine.
My secret to long sportster life, about 75 HP is good, bronze oil pump gear, top end job around 65000...
Originally Posted by Diogenes415 View Post
I think the Evo Sportster motor is one of the simplest, robust and beautifully designed motors to have ever been produced.
interesting thread
agreed
i rolled more than 130.000 kms with Sporties and obviously nowadays is the bike i know deeply compared to other metrics i ride once in a while... or compared to metrics i rode for years in the past...
personally i think my secret to a long Sportster life (with my limited mech skills) is to leave her engine alone (I.E. no transformations or conversion) and take care and inspect her after any ride how would do a pilot after any fly with his bird...
as for the blow by... my old ride after 80k kms had a lot of that at high revs... i thought it would be caused to worn piston rings though
rainbows from other worlds have colours that i don't know
Old 25th September 2018
Diogenes415's Avatar
Diogenes415 Diogenes415 is offline
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL883C
Diogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond repute
... as for the blow by... my old ride after 80k kms had a lot of that at high revs... i thought it would be caused to worn piston rings though
Usually when we say/write 'blow-by' it refers to combustion gases getting past the piston/rings which pressurizes the crankcase. We (or at least I) did not intend to use 'blow-by' to mean excessive oil vapor getting past the breather/umbrella valves.
Nope, it's a Sportster.
Nibelungen's Avatar
Master Bike Builder
Uh... then what term do you use to describe that?
It would probably have to be more specific like 'breather valve blow-by' or something along those lines so as not to be confused with the way 'blow-by' is typically used in the context of crankcase pressurization. If this language were Deutsch we could just coin a new word like 'breatherventoilpuking'.
Nibelungen's Avatar
Master Bike Builder
Get it
some other members though refer to that simply with blow by... but maybe i'm wrong...
after all it was me the guy who is speaking in another langauge
Hey, I'm the guy who used the less common term 'mushroom' instead of the more acceptable term 'umbrella' valve. Believe me, I understand the language barrier thing, it took me many years to have English become my primary language.
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
I'm at 91.5k miles on my bike. The only thing I would call a "major" issue is when I had the main drive gear output bearing let go. Very similar to Chris's bearing failure. The cage let go and the bearing followed.
When I rebuilt it I put 100% metal caged bearings in except for the ones that go on the trans. shaft under the gears. No other option for those, but they're more reliable. The only reason they run the PA66 cages is for noise. They have better lubricity, but in the applications used here that's not really an issue.
Other than that the only thing is the Hammer 1250 kit put on about 43k miles in. Blowby hasn't changed since install, about 1qt per 5k miles.
Old 28th September 2018
201648Rider 201648Rider is offline
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future
Lost my engine around 13k.
Just 2 months after installing v&h cleaner, fuelpak, and shortshots on a stock 48. Bike was always dealer serviced.
Lots of headaches later I've concluded I sucked water into the cylinder. So I can't really blame the evo for bending its rods.
Found a low mile ebay engine, tossed on a hammer 1275 kit, and a damn aircleaner cover, and sitting around 22k miles now.
Old 3rd October 2018
polaris0352 polaris0352 is offline
Other Motorcycle Model: CB450
Other Motorcycle Year: 1974
polaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the rough
I'm a German auto mechanic. This has me rolling currently. Absolutely right up the alley of that "technical" German that is always so hard to get translated.
Old 4th October 2018
BKB's Avatar
BKB BKB is offline
Had the shifting bits go south on my '09 at 70,000 miles. And the clutch. I don't know if the one problem caused the other. First it got hard to up-shift into 4th. Everything else worked OK. Then the clutch started to slip about 5,000 miles later. 400 miles from the house. By the time I got home, it wouldn't go up into 4th at all. The rest of the motor, when it was all apart, looked fine at the shop. 22,000 miles later, & it's still good. None of the techs at the dealer could tell me what caused it. A detent ball had cracked, or the bits that the ball slides into had broken. Then other stuff got bent, but only enough that they actually had to get out the calipers & micrometers to see what was messed up. They put the gear box back together 4 times before they finally got all the right parts & got it to shift correctly.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
