0 2017 Headlight in 1991?
Last Post: vt883
0 WTB 67698-81D Headlight Assembly
Last Post: vt883
0 My Patriot Defender Knock-Off
0 New Sporty in Dallas, TX
0 Sportsterpedia Progress
4 Scared for my rod bearings after cam removal...
Last Post: farmall
5 WTB / ISO: Mid Controls for Frame-Mount Evo (2001 in my case)
Last Post: racemoto
0 exhaust or cams?
0 Bendix / Zenith questions
Last Post: farmall
0 Ohlins sell to Tenneco
Last Post: Reverend G
5 WTB / ISO: Riser, relatively low handle bars, speedometer mount
Last Post: racemoto
Last Post: Scott
0 35mm showa damper seal rings???
0 Cutting drag pipes to use OEM type mufflers...
Last Post: DirtyHarry68
5 Jiffy Standing
5 Eye Protection When Riding?
Last Post: clif02
0 Harley-Davidson Sportster: Merging The Modern With The Timeless
Last Post: Caustic Dick
0 New handlebar wiring harness 81XLH?
Last Post: owlsplace
0 If you could only have one bike, would it be a Sporster?
Last Post: clif02
0 Wire gauge for solenoid
Last Post: LenC
0 Ceramic Coating My Paint
RLAnderson (58), boomer (53), ESCOBAR (47), davenjeip (46), BLOODYKNUCKLES (43), Shudabenz (40), Sporre96, 071200low (35)
Old 3rd November 2018
OKHD OKHD is offline
OKHD is an unknown quantity at this point
Default EFI Sportster Relocating Starter Switch
I have a 2014 883N, I’m trying to de clutter the handle bars. I removed the Left controls, but having some problems with the right side. I’m wanting to hardwire the kill switch to delete it and move the starter switch. Does anyone know what wires I need to use? A schematic?
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
2014+ is CAN Bus, so I think it's going to be tricky.
Folkie
South East England Riders
Old 4th November 2018
send me a pm with an address to send it to. i have info on 2013 but should be the same for 2014.
shanneba shanneba is offline
Here is a link to the wiring diagrams:
https://serviceinfo.harley-davidson....t/view?id=5541
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
sportsterdoc's Avatar
2014 up are CANBus...a totally different animal
http://xlforum.net/forums/showthread.php?t=1995444
Folkie's Avatar
Brass Nut
That's what I'm saying.
believe it to be doable.
power comes in on the grey with and leaves on the white/black (switched power to ecm)
if the kill sw is opened, switched power is lost and ecm shuts down engine, no fancy can here. if joined, then power is supplied all the time and no kill function.
the start is doable but i will have to print out as scrolling the pdf sucks and i can not draw on it. the start relay is set operation via the tsm/tssm. will have to jump back. but i can send you the entire electrical.
ok, i'm back
it appears that power on the grey is jumped to the bar start sw. nothing new, been like that for decades. (if you open the kill sw then the start will not work).
the black/red from the bar sw sends power to one side of the start relay coil.
the other side of the coil is tan/green and runs to the tsm/tssm/hfsm module start control pin.
if the module says good to go, it grounds the tan/green, relay pulls in and the starter functions. (with start button pushed in)
so you could put the switch anywhere you want, just have to bring the wiring with it be jumpers or what not>
ok, i'm back
I didn’t see a black/red wire. All I have is white/ black, white/ red, red, black, and the white/ grey (or vise versa). Or is that wire further down at the start relay coil?
White/gray is engine stop
Red/orange is from battery fuse
Black is ground (black/green at connector)
White/red is CAN hi to ECM position 14
White/black is CAN lo to ECM position 13
check FSM figure A-8
The microprocessor in the unit provides input from RH switches to the ECM via CAN hi or CAN lo
