0 My 1988 basket case has a belt? Should I keep it?
0 New rider, first ride
Last Post: old dog
0 Controls replacement switches?
0 Have my cake and eat it too? 1275 + 570s + CVJ
Last Post: toe
Last Post: Ted Town
0 Riding jackets
0 How many helmets?
Last Post: Bama Lee XLC
0 New from Washington
0 69/50 Fest: The 50th Anniversary of the 1969 Sportster (Fall 2019 GBB) 9/14/19
0 Tour of Honor
Last Post: Traxx
0 Need help with S&S GB carb
Last Post: RKN
0 An Ohio Meet 'N' Eat
0 Starting woes :(
0 Seeley Ironhead race bike
Last Post: ex119x
Last Post: Boil1337
Last Post: 02vette
14 Post your Bike in a Cemetary Pic
Last Post: Lone Rider
0 70 XLCH Piston, Connecting rod issue
0 dual carb heads on ebay
0 hmmm, whaddaya think? (Footpeg Location)
Last Post: slcharger
Zanzibar, stvmike (65), Leroywulf (61), Erik (58), SoCal Harley (53), drew96 (41), Reverend_d (39)
Old 8th November 2018
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
if they are not there, nothing for the controller to see
I'm probably wrong about this, but I got the impression that the ECM / BCM wouldn't be happy if it couldn't see something?
Folkie
South East England Riders
sportsterdoc's Avatar
The BCM must monitor lighting circut resistances to signal a bulb is out.
I am NOT a CAnBus expert, so I am no going to go farther with this...simply pointing out the challenges to 2014 up electrical mods.
Originally Posted by sportsterdoc View Post
Ignition switch, if present, has ground, 2 resistors and white/blue wire to BCM C3
Diagram is on figure A-9 main harness 1 of 2, bottom left
I did create an alternative circuit for using a Standard Generic 3-Position Keyswitch (like pre-2014) to replace the one that HD uses on the CANbus models. It presumes you are connecting it to the same BCM contacts as stock.
It's in the Sportsterpedia REFERENCE Section:
http://sportsterpedia.com/doku.php/t...bus_key_switch
Although I haven't tested this circuit, I am confident it will operate correctly.
IXL _______ >>>> My Motorcyle Chronicles Are Here<<<<
Check Out The Sportsterpedia
Old 9th November 2018
Looks good, from memory same as optional switch on 2014 up.
Wonder what factory 2014 up ignition costs?
Ronnie's Microfiche - Factory Keyswitch (2017 1200C):
71400083 - SWITCH, IGNITION, W/ REF # 16 (SPECIFY KEY NUMBER) - $122.49
the whole point of CAN is that there is no central computer like was in past days where some minor thing goes south and you have to replace the whole she-bang.
CAN is made up of modules. now all modules must know what is going on, so the bus line.
CAN is parallel and not series, so removing a module off the bus does not effect the bus or communications. now i am not saying if you remove a CAN component that it does not effect others that rely on the info it provided. but some CAN components are not essential, lighting probably one.
in CAN, there is an heirarchy so some things take priority so other things get pushed aside until the bus is cleared for it, same thing in a computer.
when your computer needs to do something, an interrupt request is made, if the cpu has the time for it, it gets done, if not, it has to wait. the same goes for CAN. if a module needs to send out info, the can-lo will drop in voltage telling the system that info is needing to be transmitted. when all the modules agree, the can-hi will rise in voltage and the module will pass on the info. if the module has nothing to say, the can-lo & can-hi remain at the same voltage. typically a 5 volt is used and each line will have 2.5 volts, however, whether hi or low, the sum will be 5 volts.
there are checks and balances built in and the module that is transmitting will look for itself and within the transmitted info is like a check sum bit. there are several layers of CAN.
Old 10th November 2018
Ouch!
