0 Gave up and made a bigger fuel tank (see pic)
0 Poweraythor alternator conversion
0 Which cams ?
Last Post: gusm2
0 The White Bike is the Right Bike Thread.
Last Post: A Seabee
0 need service information for my '71 Ironheqad
0 Torque Cones
0 Throttle Cable Adjustment Question
Last Post: Model H
0 Stator wire hot!
Last Post: oldboy
Last Post: Lowe175
0 Happy Birthday 'jzink0883'
0 will not start
Last Post: 01rk
Last Post: sprink
0 For Sale: 2012 XR1200X
Last Post: joes95bobber
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
6 1997 Sportster S putting +4 front shocks??
0 Wet sumping?
0 Some oil issues!
0 Marshwood Vale, 17th June 2019
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
Old 4th November 2018
ncxl ncxl is offline
Sportster/Buell Year: 2016
ncxl is an unknown quantity at this point
Default Purchasing a 2016 XL 1200C soon
After a few years and a few different scoots I'm heading back to get a 2016 1200 custom.
I've previously had a 1996 1200 and a 2008 1200C, last time on a sporty was about 6 years ago.
The 2016 I'm looking at has only 1400 mi and is very clean.
Are there any potential issues to be aware of or to look for before closing the deal?
Thanks
KG
DFuller1980 DFuller1980 is offline
DFuller1980 is an unknown quantity at this point
Thanks
KG
That new of a bike all should be good. The only thing I worry about with low mileage used bikes would be leaks from seals that have spent most of their time sitting shrinking and getting hard. But a 2 year old bike shouldn't have any issues. May even still have factory warranty. Just enjoy it. All should be good. I would bring up getting the brakes flushed if your buying from a dealer. It's do for that at 2 years. If it hasn't already been done.
Sent from my XT1635-01 using Tapatalk
wedge's Avatar
wedge wedge is offline
I would think it is a lot like your 08 was. If you were happy with that bike you should like this one.
Sounds like you have been around bikes a while. It's just like anything you buy, look it over good, check out the general adjustments, smell the oil, dip a stick or something in the oil bag and look at the color. You will be able to see if the guy took care of it or not. It's near new, with low mileage, so even a clown owner couldn't have messed it up too bad.
ochog1's Avatar
ochog1 ochog1 is offline
ochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to beholdochog1 is a splendid one to behold
Not really the sportster is about the most bulletproof bike H-D makes IMHO. I always have a sporty even though I have BT’s it’s just a lot more convenient to hop on it when screwing off. Just keep up with the normal crap oils, battery, tires and you should be good to go.
Old 5th November 2018
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
I've only bought one Sportster used, my current one. It had the extended warranty intact which came in handy. Due it's low miles sitting for years in a garage, the rocker box cover gaskets started leaking. The warranty covered it. Zero issues after that.
So you might consider extending the warranty if it's fairly cheap. Otherwise don't worry about it.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
jzink0883's Avatar
jzink0883 jzink0883 is offline
Sportster/Buell Model: XL1200CP
Sportster/Buell Year: 2015
Sportster/Buell Model #2: XLH1200 (traded in)
Sportster/Buell Year #2: 1998
jzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond repute
Thanks
KG
Get rid of the spring plate!
Save up for mini-apes!
jzink0883, '15 XL1200CP, it ain't butt jewelry, it's a ride
Old 12th November 2018
Souzafone Souzafone is offline
Souzafone is an unknown quantity at this point
Replace the air cleaner with one using a separate breather so your bike isn't inhaling it's own crankcase fumes.
Old 2nd December 2018
After a short delay I finally got the deal finished.
reunited with Sportster after being away for several years. The 16 certainly rides and handles better than the previous 2008.
Now waiting for the weather to clear up so I can ride.
sportsterdoc's Avatar
Congrats!
Before contemplating any wiring mods, understand that 2014 up is a CANBus system.
2007-2013 wiring
http://xlforum.net/forums/s....php?t=1869053
CANBus (2014 up)
http://xlforum.net/forums/s....php?t=1995444
Old 3rd December 2018
Eric Von Zipper's Avatar
Eric Von Zipper Eric Von Zipper is offline
Sportster/Buell Model: C for Chrome
Eric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant future
Hope you dont mind the huge front tire, Keeping my 08 for the rest of my days.
The last good "C" was 2011.
