0 2017 Headlight in 1991?
Last Post: vt883
0 WTB 67698-81D Headlight Assembly
Last Post: vt883
0 My Patriot Defender Knock-Off
0 New Sporty in Dallas, TX
0 Sportsterpedia Progress
4 Scared for my rod bearings after cam removal...
Last Post: farmall
5 WTB / ISO: Mid Controls for Frame-Mount Evo (2001 in my case)
Last Post: racemoto
0 exhaust or cams?
0 Bendix / Zenith questions
Last Post: farmall
0 Ohlins sell to Tenneco
Last Post: Reverend G
5 WTB / ISO: Riser, relatively low handle bars, speedometer mount
Last Post: racemoto
Last Post: Scott
0 35mm showa damper seal rings???
0 Cutting drag pipes to use OEM type mufflers...
Last Post: DirtyHarry68
5 Jiffy Standing
5 Eye Protection When Riding?
Last Post: clif02
0 Harley-Davidson Sportster: Merging The Modern With The Timeless
Last Post: Caustic Dick
0 New handlebar wiring harness 81XLH?
Last Post: owlsplace
0 If you could only have one bike, would it be a Sporster?
Last Post: clif02
0 Wire gauge for solenoid
Last Post: LenC
0 Ceramic Coating My Paint
RLAnderson (58), boomer (53), ESCOBAR (47), davenjeip (46), BLOODYKNUCKLES (43), Shudabenz (40), Sporre96, 071200low (35)
bassani, fp3, map, pop
Old 6th November 2018
motomike101 motomike101 is offline
Sportster/Buell Model: 883n
motomike101 is an unknown quantity at this point
Default Bassani Road Rage III and V&H FP3 XL1200
Hi guys,
So just got back onto a sporty and am happy to be back on it! Anyways I put on a Bassani Road Rage III Stainless Steel pipe and a V&H FP3. Trying to set the base map and as close as I can guess the 2 into 1 Slant pipe is the closest to the bassani. Tried the comp 2-1 and it fell on its face and the generic map was poppy as all heck. Anybody out there have any luck with this. Oh and I emailed V&H already.
Thanks!
DFuller1980 DFuller1980 is offline
DFuller1980 is an unknown quantity at this point
Originally Posted by motomike101 View Post
Hi guys,
Thanks!
Call V&H and they will walk you threw what map will work best. You can call from the app. Also you are likely going to have to auto tune a lot of that out. I put Short Shots on my Iron and flashed it with the correct map and it popped and spit like crazy. Give the bike about 2 tanks of gas to get used to the new map and then start auto tuning. Man I tell you the auto tunes I did fixed every bit of running issues and I gained back some fuel mileage. Good luck man.
Sent from my XT1635-01 using Tapatalk
Thanks I guess i'll just keep trying V&H and then auto tune. Was hoping it was plug and play.
Sometimes they are BUT what I've found is that smaller displacement bikes AKA Sportsters tend to be finicky when changing maps. Every big twin I've helped remap required no autotune. Trust me it will run great after the auto tune. I found it worked best to do the auto tune is 3 back to back sessions. When you autotune and fill some blocks stop, apply changes and keep autotuning. I would tune once in town stop and go, then hit the highway at normal speeds, then finish up with a high speed run. Constantly changing speed and throttle settings. I did these sessions 3 different times and it gets better and better after each one.
Thanks for the advice on this!
