0 sporty
0 A different Oil filter test
0 Tacho Ratio's
0 Replacing Stock Sealed Beam Headlight in my 1991
0 Air Filter Soaks With Gas
0 Gotta Start a Thread for the Streetfighter Too!
Last Post: 83XLX
0 1980 Sputhe Sportster
0 Supertrapp exhaust too &%$#in loud!
Last Post: themadone
0 Forum problems???
0 1987 XLH1100 Gas in Oil tank
Last Post: rebel7
0 Hello from the Netherlands!
Last Post: khav
0 Khk flywheels in my ironhead....timing
Last Post: vonhatch
0 Cv carb jet question
Last Post: Bob F
0 Harbour Freight jack
Last Post: Bob F
0 Safety Announcement; Re: Saint Patrick
0 900 dual carb front head
Last Post: Bryan83taco
0 Replace crank bearings
Last Post: Maxdog2
0 VOES Switch on CV carb conversion.
Last Post: BlackAce
0 HD 100th Anniversary Sporty Pic Thread
Last Post: MoneyFor
0 LED turn signals problem?
Last Post: Scuba10jdl
drifter44 (75), Streak70 (71), Rayzer (61), ridefree1 (57), erk (53), LOBO (51), motley79 (40), polaris0352 (38), TManos916 (38)
Old 25th December 2018
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud of
As mentioned, you got off lucky if all that happened was the dip stick blowing out. It's a lot worse when the tank explodes under your seat while riding like mine did, but my incident was from running the bike at to low a temperature causing the oil to turn to slush in the lines and causing pressure build up. As Dan said, you should check the seams on that tank anyway. I believe the newer models have some sort of pressure relief valve on the tank to prevent this from happening. I don't know what year they started that though.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
rejeanprimeau's Avatar
I've never done any of that and I got 206,000 miles out of my 2006 Sportster before I killed it. But if that makes someone comfortable then keep doing it.
Then do it to all your cars, lawn mower and other vehicules you own.
Just running old oil seem to be the reason you've run so far.
I live in Kebec, up there where it's cold 6 month per year, I change my oil before winterizing. Every 5000 km I change; averaging about 15 K km a year, so three oil change a year. 3 quarts more for my peace of mind.
Scavenge oil change is just a better way than leaving 25% of old oil in an engine, Why not leave 100% old oil ???? 25% dont mater after all.
You might have got better than 206K if you've done it.
You already convince peoples to harm their engine by running 25% old acidic oil. Good for you and them.
Old 26th December 2018
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
My engine failed because the cardboard seal from the inside of an oil cap fell into my oil tank and blocked the flow of the oil causing oil starvation. Prior to that occurring I could still see the cross hatching in the cylinders and I was burning no oil.
As I've said, if doing the flush makes you more comfortable then keep doing it, I was not criticizing you or anyone else. I was simply stating my experience.
John Wayne - "The Shootist"
Click here to listen to my interview on the Motorcycle Men Podcast
The flush is another precaution, I advocating scavenge oil change. Yes I will continue to do it.
Old 28th December 2018
Mike'sXL883 Mike'sXL883 is offline
Sportster/Buell Model: XL883L
Sportster/Buell Year: 3
Mike'sXL883 is an unknown quantity at this point
I'll check the tank for any breach. That is sound advise.
I guess what is baffling me is that I did not blow an o-ring or seal first?? It would be nice to know what the pressure rating of that cap is. Anyone know????
That oil cap is like a twist lock and it pushed the plastic tabs apart. I had to kind of twist it back together.
There is an oil tank and twist cap on e-bay for $50, & I might buy & change it for piece of mind.
Old 4th January 2019
Default Incase you wanted to see the bike
See video at:
https://youtu.be/js8mavf6J3o
ParrotHead's Avatar
Originally Posted by Mike'sXL883 View Post
Nice, good luck with it
