0 Benelli tank on 79’ sportster
0 Share your Man Cave Garage ideas
Last Post: Yakcm2
Last Post: okiejim
0 lighter clutch
Last Post: priell3
0 Questions on popping after start
0 Black Friday 2019 deals???
Last Post: Turbo Sporty 48
3 Shaky Dave Recovery
5 What year is the most collectible Sportster.
0 What weight oil?
0 Sportster Tacho
Last Post: MrYeats
0 xlcr elusive parts
Last Post: Speedyone
4 The no-debate OIL POLL
0 Wet Sump Ifo, fix and tools
0 70 XLCH Piston, Connecting rod issue
Last Post: Wilkinson949
0 Think my stator needs replaced
0 Huge cock up (XR1200 Clutch Mod)
Last Post: THEWILDONE
0 Cheap 7200B bearing = NO!
0 Grüezi aus der Schweiz
Last Post: DéDé
Old 24th December 2018
Nytstr's Avatar
Nytstr Nytstr is offline
TurboMafia Charter Member
Sportster/Buell Model: XL1343NT LSR #1171/1175
Sportster/Buell Model #2: XL1250RT
Other Motorcycle Model: FXRP
Other Motorcycle Year: 1986
Nytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant future
Default Pivot bolt torque spec
I've converted my 2007 Nightster to the newer style swingarm pivot bolt. fNot sure what year that appeared, but it uses one bolt going all the way through the swingarm pivot. Does anyone know the torque value for that?
Turbo Mafia Charter Member
Current LSR Record Holder: A-PBG 1650 134.594
RIP Sky Sanders
TGB #8
Support Your Local Land Speed Racer -
The Last Truly Amateur American Racing!
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
FSM on a 2006 is 60-70 ft lbs.
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
It came in in 2014. I'll look up the torque spec.
Folkie
South East England Riders
Folkie's Avatar
Brass Nut
It's 120 - 130 ft-lbs. That's from the 2015 FSM, with the new one piece bolt.
Nytstr's Avatar
Thanks, Folkie. I knew it was different from the old setup.
Sent from my VS988 using Tapatalk
Old 25th December 2018
BKB's Avatar
BKB BKB is offline
Nytstr, is that a direct replacement swap into the older swing arm pivots? I would guess the bearings & clips would also be needed, but can you take the old bits out & just put the pieces from the '14 & up right in?
Folkie's Avatar
Brass Nut
Good question.
Nytstr, What parts did you have to use to make the change besides the bolt?
Joe
shanneba shanneba is offline
It looks like just the bolt and nut are different.
The old style takes 2 bolts, no nuts.
You would likely need the new swing arm pivot shaft from the rear engine mount assuming the threads for the old style are in the pivot shaft.
New
47500004 SHAFT, SWING ARM PIVOT 1 30.99
2016 XL1200C engine mounts
Old
41568-04 SHAFT, SWING ARM PIVOT 1 30.99
2013XL1200C engine mounts
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 29th December 2018
BKB's Avatar
BKB BKB is offline
Nytster hasn't come back to answer my question, so I looked all the part #'s on Ronnies microfiche. The part #'s for the bearings, bearing retainer rings & isolators were the same. The pivot shaft, the longer single thru-bolt, nut & retainer clip were the 4 parts that were different. It appears to me that those 4 parts will directly replace the 2 bolts & pivot shaft, with no other changes needed. Pretty straight forward swap, as near as I can tell.
I need to be checking the swing arm on my 93,000 mile '09 for bubbling paint &/or corrosion in the near future. If it needs to be removed to be cleaned or repainted/powder coated, I plan to do this conversion. If I do end up doing this I will come back here to follow up & let y'all know how it went.
