0 Gave up and made a bigger fuel tank (see pic)
0 Poweraythor alternator conversion
0 Which cams ?
Last Post: gusm2
0 The White Bike is the Right Bike Thread.
Last Post: A Seabee
0 need service information for my '71 Ironheqad
0 Torque Cones
0 Throttle Cable Adjustment Question
Last Post: Model H
0 Stator wire hot!
Last Post: oldboy
Last Post: Lowe175
0 Happy Birthday 'jzink0883'
0 will not start
Last Post: 01rk
Last Post: sprink
0 For Sale: 2012 XR1200X
Last Post: joes95bobber
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
6 1997 Sportster S putting +4 front shocks??
0 Wet sumping?
0 Some oil issues!
0 Marshwood Vale, 17th June 2019
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
Old 29th December 2018
Nytstr's Avatar
Nytstr Nytstr is offline
TurboMafia Charter Member
Sportster/Buell Model: XL1343NT LSR #1171/1175
Sportster/Buell Model #2: XL1250RT
Other Motorcycle Model: FXRP
Other Motorcycle Year: 1986
Nytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant future
Originally Posted by BKB View Post
Nytster hasn't come back to answer my question, so I looked all the part #'s on Ronnies microfiche. The part #'s for the bearings, bearing retainer rings & isolators were the same. The pivot shaft, the longer single thru-bolt, nut & retainer clip were the 4 parts that were different. It appears to me that those 4 parts will directly replace the 2 bolts & pivot shaft, with no other changes needed. Pretty straight forward swap, as near as I can tell.
I need to be checking the swing arm on my 93,000 mile '09 for bubbling paint &/or corrosion in the near future. If it needs to be removed to be cleaned or repainted/powder coated, I plan to do this conversion. If I do end up doing this I will come back here to follow up & let y'all know how it went.
Sorry I didn't get back sooner. Yes, you are correct, it is a direct swap. I also have the Vance & Hines replacements for the rear rubber isolaters. I first did this on my Bonneville bike, then on my Roadster. So far no problems.
Sent from my VS988 using Tapatalk
Turbo Mafia Charter Member
Current LSR Record Holder: A-PBG 1650 134.594
RIP Sky Sanders
TGB #8
Support Your Local Land Speed Racer -
The Last Truly Amateur American Racing!
Old 31st December 2018
BKB's Avatar
BKB BKB is offline
Excellent! Thanks!
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
