0 Who's still riding???
Last Post: bplinson
0 Stabliser Tie-link 16232-04
Last Post: Vohnsen
0 Top End Not Oiling
Last Post: Vanmor
0 Winter Sucks
0 Her indoors
0 Big Bore '03 883R :)
Last Post: t120r
Last Post: drumbrake
Last Post: Jarlaxle
Last Post: T_worth
Last Post: Bama Lee XLC
0 Shipping woes
0 In Tank Oil Filter?
0 Valve guide replacement SOP
Last Post: NHPS
0 04 Battery Cover on a 95
Last Post: F1J1
Last Post: sltm1
Last Post: Jarlaxle
0 What oil temp do you run
Last Post: JKKO
Old 1st September 2008
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
I'm quite happy with the sound of Krome werks slip-on's 25lbs of potatoes worth
If you want to lower the idle you would have to use a race tuner or the new TTS product if you don't want to purchase aftermarket ECM.
In three words I can sum up everything I've learned about life: it goes on.
Old 2nd September 2008
krono's Avatar
krono krono is offline
Sportster/Buell Model: XL 883
Sportster/Buell Model #2: XL 1200 C
Sportster/Buell Year #2: 2008
Other Motorcycle Model: Motomel X3M 125
Other Motorcycle Year: 2007
krono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of lightkrono is a glorious beacon of light
Originally Posted by JStreitz View Post
As far as I know, there is no way to lower the idle on an EFI bike. The ECM controls it. Maybe there is an aftermarket controller or something that can change it.
I sent a email to dynojet asking about this...
they replied
"You can adjust the amount fuel the bike gets at idle and that in turn will affect the idle speed."
(using the power commander III USB)
so, I ordered one last saturday, should take like 15 days to be here, I can't wait to test it
Krono in Argentina
883 XL 2004, 1200 C 2008, Daelim Liberty 50cc, Motomel X3M 125
My Wife Yes. My Dog Maybe. My Harley?... NEVER!
Old 4th September 2008
txpetroguy txpetroguy is offline
txpetroguy is an unknown quantity at this point
I just re-installed the baffles in my SE Slip-ons after the following modifications were completed:
1. Removed the fiberglass wrap and screen.
2. Drilled out all the holes with a 3/8" drill bit
3. Drilled out an addtitional eight holes following the existing pattern. (3 of which were on a row by themselves opposite side of the diverter tab)
4. Drilled a 3/8" hole in the center of the diverter tab.
The result was a much deeper sound during idle and a progressively increasing sound on acceleration. I'm running a stock a/c with no ecm mods on a 08 1200C.
Old 9th September 2008
josechopper's Avatar
josechopper josechopper is offline
Sportster/Buell Model: 883-R
Other Motorcycle Model: CHOPPER
Other Motorcycle Year: 1990
josechopper has disabled reputation
perfect krono, you are the I number 1, take care that burn
live to ride ride to live
Rehit's Avatar
Rehit Rehit is offline
Other Motorcycle Model: CVO Dyna Low
Other Motorcycle Year: 2008
Rehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to allRehit is a name known to all
i have Rinehart crossback 2 into 2's and the potato sound is there...
it just depends if you want to spend that much on a set of pipes...
2008 1200N
RINEHART RACING CROSS-BACK 2-INTO-2 EXHAUST
SCREAMING EAGLE HIGH PERFORMANCE CAMS
SCREAMING EAGLE RACE TUNER
SCREAMING EAGLE HEAVY BREATHER
Old 10th September 2008
Willie D's Avatar
Willie D Willie D is offline
Other Motorcycle Model: 2008 KLR650
Other Motorcycle Year: 1982
Willie D is on a distinguished roadWillie D is on a distinguished roadWillie D is on a distinguished roadWillie D is on a distinguished road
Thumbs up exhaust change
I have that sound with V&H shortshots w/Quiet Baffles. I used the nightrider 02 IED to fatten it up to 14.2 AFR and now it really hauls the mail. still use the stock AC.
JM.02 worth.
Old 27th September 2008
Costeve's Avatar
Costeve Costeve is offline
Sportster/Buell Model #2: Nightster (gone)
Sportster/Buell Year #2: 09
Other Motorcycle Model: Softail Deluxe (Daily rid
Costeve is on a distinguished roadCosteve is on a distinguished road
Seriously! The info and work put into the experimentation and then the reporting to all of US on it is Awesome!
How the hell is that burn doing anyhow!!?!?!!!
krono's Avatar
thanks!
the burn is 100% ok, healed pretty fast, no scar, just red skin zone. thanks for asking
btw, I got today my power commander III, when I get the map right, I will share it... so far can't put the seat back on will try again tomorrow
Old 29th September 2008
vilification's Avatar
vilification vilification is offline
Other Motorcycle Model: Suzuki DR350SE
Other Motorcycle Year: 1994
vilification is an unknown quantity at this point
I have a 2008 Nightster and used the 1 3/4" hole saw removal tool for my baffles. I really like the sound compared to all my friends various after market pipes. It has a much lower note to it. Very low frequency. I set off car alarms just putting by. Its not loud, just very low. Although its loud if you "get on it"
Old 5th October 2008
im_justin_sane's Avatar
im_justin_sane im_justin_sane is offline
im_justin_sane is an unknown quantity at this point
I put on a set of Samson Legend pipes, and it made a huge difference in both sound and throttle response. Out of pure paranoia, I took my 08 1200C to the shop and had them do a software download change to adjust the EFI. I've read that exhaust swaps results in a too lean EFI setting, which would fubar the engine. I didn't want that, for obvious reasons. The idle is maybe a tad lower, and it has a kick arse potato sound, if a little fast for that 'traditional' Harley low idle sound. That's what we get with Sportys...higher idle...hell, that means she's ready to rip!
I'll probably toss in a better air filter and call the performance upgrades done. I've had it a year now and have blown away too many other bikes to count. I just wish the seat had a better buttstop. With forward controls and the sloping seat, it's easy to bury the throttle and have your butt on the rear seat.
Back on topic, though, going with a complete exhaust swap, while expensive, is probably the best way to go. Drilling out baffles and mufflers is just going to cause engine problems with these EFI engines. The easy flowing exhaust lets the THUMPthumpthump (not putputput) out and everyone will see you. So give the Samson's a look if you have about $550 to spare.
When I started pushin' 40, I started pushin' BACK!
