Last Post: toe
0 Poll: What weight fork oil do you use?
Last Post: rezchug
0 Happy Birthday 'jzink0883'
Last Post: Lowe175
0 Marshwood Vale, 17th June 2019
0 Wet sumping?
0 Been Sitting For 5-10 years; Starts, But Dies
Last Post: Feskerlars
0 Front brake is terrible
Last Post: Hopper
0 Poweraythor alternator conversion
Last Post: saddlebagrail
0 2014 swingarm axle in earlier rubber mount
Last Post: jazzman
0 Does anyone run the Machinist Mike “hydro clutch?” If so how do you like it?
Last Post: Rolli
0 Gave up and made a bigger fuel tank (see pic)
0 Which cams ?
Last Post: gusm2
0 The White Bike is the Right Bike Thread.
Last Post: A Seabee
0 need service information for my '71 Ironheqad
0 Torque Cones
0 Throttle Cable Adjustment Question
Last Post: Model H
0 Stator wire hot!
Last Post: oldboy
0 will not start
Last Post: 01rk
Last Post: sprink
0 For Sale: 2012 XR1200X
Last Post: joes95bobber
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
Old 25th September 2006
Turbota's Avatar
Turbota Turbota is offline
Here is my "MAP Modified 35" program.
MAP (kPa) 20 on the SE Race Tuner MAP is the same as the 16" Hg on my chart (this is idle throttle manifold pressure)
MAP (kPa) 100 on the SE Race Tuner MAP is the same as the 30" Hg on my chart (this is wide open throttle manifold pressure)
04 XL 1222R
Turbota's Avatar
Originally Posted by dieselvette
Does anyone know what the ICM reflash for 04 models changes exactly?
The 04 module reflash just adds 2 degrees of timing at idle and the area just off-idle (such as the area that's effected when 'blipping' the throttle from an idle). This prevents most carb farts. The reflash also modifies the VSS freq. slightly to correct for the speedo indicating slightly higher than it should be.
Old 31st October 2006
fealingood's Avatar
fealingood fealingood is offline
fealingood is an unknown quantity at this point
Post them 1200 stage 2's on here so I can look at them please!
Old 2nd November 2006
stimbrell stimbrell is offline
Sportster/Buell Model: 883/1250R
Sportster/Buell Model #2: Buell 1125R
stimbrell has disabled reputation
I have the SE ignition race tuner and the differences in the 1200 stage 1 map for the 06's is interesting, more RPM points in the 07 map as well, picture attached.
Steve
Old 10th November 2006
Johnny G's Avatar
Johnny G Johnny G is offline
Riding with Angels
Sportster/Buell Model: Darkside
Other Motorcycle Model: Harley Davidson FLHTPI
Johnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enough
I have to remember what computer I put the 1200 stage 2 on . I think its on my work computer. I will check and see.
2004 FLHTPI Police Intercepter ( Black and Chrome)
Old 18th December 2006
sportin_2007's Avatar
sportin_2007 sportin_2007 is offline
Sportster/Buell Model: XL50
Sportster/Buell Model #2: XL50 Anniversary Edition
Other Motorcycle Model: 2007 FLHX
sportin_2007 is on a distinguished roadsportin_2007 is on a distinguished road
Hey Johnny G & Turbota.......Great map info, and a couple of great bikes you both have. Not to highjack your post, but can you guys tell me where you both got the laydown license plate brackets. I like em'
Thanks
Old 8th April 2007
Johnny G's Avatar
Riding with Angels
Thanks
Got mine from Sorgy's but they are easy to find ,Drag specialties has them in there catalog so any indy can order it for you
Old 13th April 2007
JBM's Avatar
JBM JBM is offline
Sportster/Buell Model: 883R 1200
JBM is on a distinguished roadJBM is on a distinguished roadJBM is on a distinguished roadJBM is on a distinguished roadJBM is on a distinguished road
Yes, 100 kPa would be 29.53 In-Hg.
But would 20 kPa not be 5.9 In-Hg then ?
1 kilopascal = 0.295 inch of mercury [0 °C]
Jan
1200cc OE pistons, XB heads, W-cams, SE SP mufflers, 1200 gearing.
Old 13th April 2007
Turbota's Avatar
Looks like the "Modified MAP 35" I wrote for the 04-06 bikes using the TC88A ignition module that I posted above is just a red X now .... So, here it is again:
Old 1st June 2007
Red's Avatar
Red Red is offline
Other Motorcycle Model: Kawasaki KLX125
Other Motorcycle Year: 2011
Red is an unknown quantity at this point
I converted 07 data for TC88A.
That's uneven very much, and different from 04-06 data.
