0 sporty
0 A different Oil filter test
0 Tacho Ratio's
0 Replacing Stock Sealed Beam Headlight in my 1991
0 Air Filter Soaks With Gas
0 Gotta Start a Thread for the Streetfighter Too!
Last Post: 83XLX
0 1980 Sputhe Sportster
0 Supertrapp exhaust too &%$#in loud!
Last Post: themadone
0 Forum problems???
0 1987 XLH1100 Gas in Oil tank
Last Post: rebel7
0 Hello from the Netherlands!
Last Post: khav
0 Khk flywheels in my ironhead....timing
Last Post: vonhatch
0 Cv carb jet question
Last Post: Bob F
0 Harbour Freight jack
Last Post: Bob F
0 Safety Announcement; Re: Saint Patrick
0 900 dual carb front head
Last Post: Bryan83taco
0 Replace crank bearings
Last Post: Maxdog2
0 VOES Switch on CV carb conversion.
Last Post: BlackAce
0 HD 100th Anniversary Sporty Pic Thread
Last Post: MoneyFor
0 LED turn signals problem?
Last Post: Scuba10jdl
drifter44 (75), Streak70 (71), Rayzer (61), ridefree1 (57), erk (53), LOBO (51), motley79 (40), polaris0352 (38), TManos916 (38)
  #51
Old 27th February 2010
whittlebeast's Avatar
Other Motorcycle Year: 2008
Red face
Originally Posted by A_Ride_4_ever View Post
i got a copy of the hqx file they use to flash with, I also dumped the rom from a stock 08 1200, im decompiling the code, what a mess..... I wouldn't call it hidden, its more or less just obscure, references to partial tables reference's to lookups in areas that aren't activated. Its almost as if there is a master table that is missing. Im about to start digging into the other promm to see if it stores a 2nd set of tables. Once done I should have an exact map of all tables including lookup and reference tables as well as be able to remove the 40+ dummy tables in the database. Perhaps if I can get this one done I will be able to do others and take the mystery out of the Harley ECU/ECM
Just the guy you need to talk to
http://github.com/ToBeFrank/HOSSTune/
AW
Old 28th February 2010
A_Ride_4_ever's Avatar
A_Ride_4_ever A_Ride_4_ever is offline
Sportster/Buell Model: Sportster 1200R
Sportster/Buell Model #2: BIG DOG
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Iron head Sportster
Other Motorcycle Year: 1970
A_Ride_4_ever is an unknown quantity at this point
awesome this is what i need :-) thanks for the link. I will get started this evening.
Respect the person who has seen the dark side of motorcycling and lived.
Old 19th April 2010
canman canman is offline
Sportster/Buell Year: 1200
canman is an unknown quantity at this point
I just put a powercommander on my 07 1200N, and im having a problem with it cutting out at idle it seems to be struggling for air at part throttle. I have hooker reble drag pipes and a xl windforce intake. powercommander told me to run the map for vans and hines shortshots and a screamin eagle stage 1. Any help would be greatly appricated.
Old 19th April 2010
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
What's a windforce intake?
Folkie
South East England Riders
Old 19th April 2010
geezer geezer is offline
Sportster/Buell Model: sportster 883
Other Motorcycle Model: To many to list.....
geezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the roughgeezer is a jewel in the rough
i have found that if you increase the numbers in the 0% throttle position colume the tickover will raise and if you decrease them the idle drops i can get my sportie to idle at 800 rpm but i get decel popping because the mixture is lean, so what i did was increase the number until the bike would idle (at normal running temp) and played with the numbers in that colume rather like you would with the idle jet on a carb, i raised the numbers up through the point that it ran smoothest till it stumbled with an overly rich mixrture and then back to the sweet spot. go up and dowm 5 at a time ie if you are at 5 try 10 etc. the sweet spot shoul have you idleing at around 1050rpm
Ride it!!
Old 18th July 2010
resdog resdog is offline
resdog has disabled reputation
Originally Posted by Turbota View Post
Since this thread is about tuning the 07 bikes with the Screamin' Eagle Race Tuner (SERT) ... Here is what your SERT ignition timing program will look like if you were to program it using the exact same data that I wrote for the Daytona Twin Tec TC88A used on the 04-06 bikes (this is called the "MAP Modified 35" program)
If you like, you can now transfer the values from the 07 SERT timing table shown below directly to your SERT programming and see how your bike responds. I believe you will be very happy with the results.
BTW ... We are using the same data shown below for both the front and rear cylinders, so apply this same data for both cylinders.
Enjoy,
Ron
Here is the timing table as applied to the 07 SERT:
________________________________________________
And here is what the above timing table looks like in 3D Graph form:
This is an awesome map but I've lost mine (computer crash). Can someone re-post the map or PM me the map? Thanks.
Old 12th November 2011
seb033's Avatar
seb033 seb033 is offline
Sportster/Buell Model: Sportster 883R
seb033 is an unknown quantity at this point
Help needed.... Can anyone send me a SEPST fuel map for 883 stock condition? Would greatly appreciate
Old 26th August 2012
Grant1 Grant1 is offline
Sportster/Buell Model: 883L Sportster
Grant1 is an unknown quantity at this point
I recently converted my 2007 883L Sportster to Stage 1. Since my bike already had RUSH Slip-Ons on it, I installed an Arlen Ness Big Sucker steel jacketed breather, and installed a Power Commander 3 USB. I hooked my sporty up to my laptop and downloaded a map that was similar to it. I wanted to know if anyone else has used the Power Commander, or has any tips or suggestions on the correct map to use? It seems that the only breather used in all the downloaded maps are for the Screamin Eagle, and my RUSH Slip-Ons aren't in there either. I am currently running with a map that lists the Screamin Eagle Breather, and Vance and Hines Slip-Ons.
Old 27th August 2012
I have a custom tuned map for the PC3 rush slipons and SE filter if your interested shoot me a PM and I will send it over. Its worked well for me. This is from a 1200r 08 It sucks gas but youl get a great deal more top-end as rev limiter is removed, it pulls well in the 3-4 k range.
