0 hi from anchorage AK
Last Post: old dog
0 Seized Oil Pump
Last Post: marklocklear
0 900 dual carb front head
0 The good and the bad
Last Post: seajay
Last Post: Four Speed
0 Air Filter Soaks With Gas
Last Post: 93sportsXLH
0 Forum problems???
0 Buell lightning
0 2 into 1 exhaust build
Last Post: cazz1000
0 Project Strociek
Last Post: Yakcm2
0 WTF Happened
Last Post: Yakcm2
Last Post: Steamboat_Willy
0 08 Nightster No Start
0 Have you ever bought Viagra or any other drug....
Last Post: jammantoo
Last Post: LLOYD883
0 Nightster suspension upgrade (RK). Who has em?
Last Post: SportyHD
5 Do you feel you pay too much for Motorcycle Insurance?
Last Post: Eric Von Zipper
Old 14th January 2007
rharrison356's Avatar
rharrison356 rharrison356 is offline
Sportster/Buell Model: XL50 #870
rharrison356 is an unknown quantity at this point
Originally Posted by doxbike View Post
I guess I didn't pose my question correctly. I already have had the re-map done after my stage 1. Can I still use the race fueler? Will I see/feel a drastic improvement or just a minor one over the currently installed re-map?
Thanks
First, I am basing my answer upon the experience of the Big Twin guys, as I don't know of anyone having done this with Sportster. Yes, you could potentially experience a performance gain using the SERF with the factory stage 1 remap depending upon your performance requirements, since the SERF allows changes (up to 50%) in the fuel delivery. However, the remap generally serves the same purpose and would likely provide better "all around" performance if using the SE a/c and slip-ons, for which the remap was designed. For mods falling outside of those parameters (such as V&H, Big Sucker and other non-HD stage 1 options) the SERF allows the owner to dial-in the ride.
The first question I would ask is, "Do you like the State 1 with HD remap?" Sporty_2007 has posted excellent results (subjectively and objectively) with his. I would be surprised if the SERF or SERT does much, if any, better. If the SERF/SERT is not dyno tuned, many of the BT quys were 5-10 HP down and 5-15% mpg off compared to bikes that had the HD remap. Speaking of dyno tuning, my XL50 is still at the dealer awaiting the new dyno going on-line (11 days and waiting...but at least it's snow and ice outside).
07 XL-50 #870 Stage 1
06 VRSCR "Hyper-fast Touring"
Kansas City Missouri
λεγει αυτω ο ιησους εγω ειμι η οδος και η αληθεια και η ζωη ουδεις ερχεται προς τον πατερα ει μη δι εμου John 14:6
Old 3rd February 2007
Drew1200c's Avatar
Drew1200c Drew1200c is offline
Sportster/Buell Model: 1200c
Drew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enoughDrew1200c will become famous soon enough
I just got a rev-tech DFO was $250 plug and play. Set up is very similar has the colored leds but only 4 pots, 1 for idle 2nd mid(main jet) 3rd full throttle (accelerator pump) 4th crossover rpm point for 3rd. The DFO can only add fuel, unlike the SERF. It works by changing the voltage pulse going to the fuel injectors. the more you turn the longer the FI's spray fuel,simple. Too bad I didnt see this post sooner or I might have considerd the SERF instead. So far the DFO works good and my cycle seems to run a lot smoother, I have not yet Dynod it. I found a local shop that said they will do a 3 run baseline for $40 ,while my local HD stealer wanted $70.
Thanks
Any changes will be minor. My original post was for Stage 1 (mufflers and A/C) without the remap. Seat of the pants was good. Then the dealer fiasco [lesson--ask and confirm] that resulted in the tuning before dynoing.
When returned for the retest, they could not get the SERF to work, so they [with my permission] did a remap and testing.
When I brought the bike home, I reconnected the SERF. I am still playing with my settings, and so far, the only improvement seems to be during the transition 3000-3500 rpm point, but I have lost the low end. I am going to wait until warmer weather (i.e., no snow on the ground) to really play with the SERF. The Big Twin guys regularly run the remap and SERF and speak of improvements. However, my dyno results show that the Air/Fuel with the remap (no SERF) are good.
Old 23rd April 2007
Goshawk's Avatar
Goshawk Goshawk is offline
Sportster/Buell Model: 1200 Roadster
Goshawk is on a distinguished roadGoshawk is on a distinguished roadGoshawk is on a distinguished roadGoshawk is on a distinguished road
When you say run through the gears do you mean you are taking the bike out on the road for a test ride? Is all adjusting done in neutral with the bike on the sidestand?
Old 5th May 2007
The adjusting is done with the bike on the stand. Fine tuning is done "subjectively" by running the bike through the gears. I am finding that the hotter temps have caused some changes, so more playing will be required.
Old 24th May 2007
joshwaa joshwaa is offline
joshwaa is an unknown quantity at this point
Thanks
Well I suppose you can adjust A/F and smell it a little more at stop lights.
Old 27th May 2007
Laker Laker is offline
Laker is on a distinguished roadLaker is on a distinguished roadLaker is on a distinguished roadLaker is on a distinguished roadLaker is on a distinguished road
Knocked-Out City Mr. rharrison356.Was that a 356 coupe?
Old 11th July 2007
Goshawk's Avatar
Thumbs up
Installed H-D race fueler today. Seems to be working but my LED lights are backwards. Green for low, yellow for mid, and red for high rpms. Will fine tune tommorrow. Thank you rharrison356. This post explains what the instructions do not.
Goshawk
Old 27th August 2007
883's Avatar
883 883 is offline
Sportster/Buell Model: XL883 (Standard)
Other Motorcycle Model: Shovel
Other Motorcycle Year: '71
883 is on a distinguished road883 is on a distinguished road
Hi,
My 883 now has 3000 miles. I new I was gonna mess with her so, I had her dyno'd at my HD dealer.
It was dyno'd at 2000 miles just when I had bolted on the Cycle Shack tapered slip-ons.
I just ordered my new SERF unit and stuffed a K&N a/c into her. I will dyno her then too.
When I can afford it, I'll be finishing her off with the Hurricane hi-flow.
How do I post my dyno sheets?? I scan them first then what???
1200R HD Heads P&P Dave Mackie, 1.94" intakes, 1.65" exhausts, SE Pro Smart Tuner
SE Pro Rocker Arms 1.725:1 Ratio, SE 551 Cams, Wiseco 10.5:1 pistons
Zippers Pro Taper Adj. PRods, SuperTrapp Supemegs 2-1 Exhaust, SE A/C.
Old 28th August 2007
Originally Posted by 883 View Post
Hi,
I look forward to hearing the results. Go to the dyno section of the forum and full instructions on posting are available. Some dealers will provide you with a "jpeg" file with the results.
