0 ****DK Custom Products Is Now Offering The Power Vision****
0 In Tank Oil Filter?
Last Post: maverick31210
Last Post: 83ironman
0 How many helmets?
5 Jiffy Standing
0 Winter reading........
0 New H-D Fully Adjustable Piggy Back Shocks And Fully Adjustable Fork Kit
14 DEAR Harley Davidson,
5 Oil pump pressure
0 Is this 1200R worth $4500?
Last Post: longride
0 Bushing alignment
0 Who's still riding???
Last Post: 1977iron
Last Post: kmul
0 THE Trainspotting Thread
hillclimber (69), burtondl2 (51), Cet (49), hagar71 (48), ShaneWolfe (47), grizdiesel (42), Confused89 (34), RAIDER0372 (33), spamer80 (33), svwannabe
View Poll Results: Has your fuel pump failed?
Yes. It did. 87 14.24%
No. It hasn't. 524 85.76%
Voters: 611. You may not vote on this poll
  #251
Old 3rd May 2017
wkong's Avatar
wkong wkong is offline
wkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to all
Just on the '07 - '09s, you mean? Mind you, my mate had an '07 883 Low, and never had a 'fuse issue'.
Yeah, as this is a thread on the 07 fuel pump I figured it would be understood I meant 07s, though I'm sure you're correct... those in parts of Arizona might have the moisture evaporate quickly enough after a rain and save them the dielectric grease every year.
Old 4th May 2017
r4fthrs's Avatar
r4fthrs r4fthrs is offline
Optimist with experience
Sportster/Buell Year: 07
r4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond repute
07, 50K no fuel pump problems- clutch, rocker cover gaskets, voltage regulator and other minor issues, but so far no fuel pump (Opps, I probably just jinked myself)
Armed you are a citizen, unarmed a subject.
Fear the government who fears your guns.
An armed society is a polite society.
Old 4th May 2017
Blues Blues is offline
Blues is an unknown quantity at this point
Mine makes weird noise every now and then. I put a spare in my saddlebag when going for a trip.
Old 23rd July 2018
Sportster/Buell Model: XLH883
hammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to behold
Default changing a fuel pump
Mine will squeal on start-up after sitting for a month or more. I am considering replacing my fuel pump on my 2012 Custom. How big of a job is it? Can it be done with the gas tank left on the bike? Thank you!
Old 23rd July 2018
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Not sure why you would want to replace the fuel pump (that start up squeal after sitting is normal, all mine do that). Depending on the miles, you may consider replacing the fuel filter.
But, replacing the fuel pump isn't difficult (same with the fuel filter). I would remove the gas tank to do it, it's simply two bolts that hold it onto the frame. You have to remove the fuel line, overflow line, and wires either way. I've never even considered doing it without removing the tank. The tank should be nearly empty, but if you set it on it's side before unbolt the fuel pump, you could probably have quite a bit of fuel still in it. Just be careful handling the fuel tank with fuel in it (it sloshes around).
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 23rd July 2018
I have intermittent issues with the bike as I ride over bumps. Considering trying fuel pump change.
Oh, how has your '07 1200R (Orange bike) been?
