0 Benelli tank on 79’ sportster
0 Share your Man Cave Garage ideas
Last Post: Yakcm2
Last Post: okiejim
0 lighter clutch
Last Post: priell3
0 Questions on popping after start
0 Black Friday 2019 deals???
Last Post: Turbo Sporty 48
3 Shaky Dave Recovery
5 What year is the most collectible Sportster.
0 What weight oil?
0 Sportster Tacho
Last Post: MrYeats
0 xlcr elusive parts
Last Post: Speedyone
4 The no-debate OIL POLL
0 Wet Sump Ifo, fix and tools
0 70 XLCH Piston, Connecting rod issue
Last Post: Wilkinson949
0 Think my stator needs replaced
0 Huge cock up (XR1200 Clutch Mod)
Last Post: THEWILDONE
0 Cheap 7200B bearing = NO!
0 Grüezi aus der Schweiz
Last Post: DéDé
View Poll Results: Has your fuel pump failed?
Yes. It did. 88 14.22%
No. It hasn't. 531 85.78%
Voters: 619. You may not vote on this poll
Old 14th June 2007
jchick's Avatar
jchick jchick is offline
Sportster/Buell Model: XL50
Sportster/Buell Model #2: XL883 (traded up)
Sportster/Buell Year #2: 2004
jchick is an unknown quantity at this point
Originally Posted by HellRazur View Post
The second choise shouldnt be No it hasent... it should be " Not Yet! "
Ditto. Mine hasn't failed *yet*, but something ain't right with the EFI system on my bike. (See herky-jerky XL50). I'd rather have carb farts, at least that can be fixed.
JC
Old 18th June 2007
MWD MWD is offline
MWD has disabled reputation
Here's a possible cause for the "fuel pump problem." Loosen your front tank bolt, and remove the rear one. Lift the back of the tank a couple of inches and set it down on a piece of 2x4:
You don't have to disconnect anything if you're careful and if you lift the rear of the tank only a couple of inches.
Now reach up into the center of the tank and pull down the fuel-pump wire. It may be taped to the tank as part of the assembly process. My wire looked like this, having been totally mashed between the tank and the frame rail.
Note the severe pinch in it from one edge of a backbone saddle trough. This is not just a cosmetic thing going on here -- we are talking about big-time pressure on a near knife-edge. I think this is the spot that may be wearing through with time and vibration.
Now drop the tank back into place and route the wire elsewhere. I winged it thus:
I'll probably tie-wrap it into place tomorrow before I hop on.
I believe the assemblers need this wire to be manufactured about six inches longer so they can put a proper loop in it, the way the service manual recommends, to keep it away from sharp edges.
I am not saying this *is* the cause of all these failures, but having a cable nearly knife-edged up against a hard surface can't be helping matters, and may be responsible for at least some of the recent non-starts.
p.s. I hope the images come through on this post. They aren't showing up in the preview, nor is the code. If I don't see them when this goes up, I'll post another reply with links to flickr.
Old 18th June 2007
MWD MWD is offline
Here are the pics:
Tank rear on block
Big pic of above
Pinched wire
Big pic of above
Wire relocated
Big pic of above
Any advice on how better to re-route this wire?
Old 18th June 2007
nightsterman's Avatar
nightsterman nightsterman is offline
nightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura aboutnightsterman has a spectacular aura about
Thumbs up Thanks for the photos!
Thanks, I'm going to check mine out in the AM.
Peace,
Mark
Old 19th June 2007
btkicker btkicker is offline
Sportster/Buell Model: 1200 Roadster
Sportster/Buell Year: 07
btkicker has disabled reputation
Great work MWD!
I checked my '07 Roadster (same small tank, efi, and all) and it's wires are where your new re-routed wires are!
Why the hell did HD move the wires only on the Nightster? I smell a recall to re-route the Nightster fuel-pump wires back to the normal spot.
again, good investigating.
Old 19th June 2007
'07 Roadster fuel-pump wires:
Old 19th June 2007
MWD MWD is offline
Thanks for that pic, BT. However, I may have confused some people. That pic of the crushed harness was taken *after* I pulled it out of the upper trough in the backbone saddle (where yours probably is right now). The crushed part was buried up between the tank and the trough. I pulled it down out of the trough and ran it straight back, avoiding either trough. In the "relocated" pic, the crushed area is invisible because it is now directly behind the tank's quick-connect.
I'm going to take a guess here: the tanks are delivered to final assembly with the harnesses taped to the bottom of the tanks, to save stress on the wires right where they enter the tanks while the tanks are being handled. If so, it's possible that the guy building my bike forgot to yank the harness free of the tape so he could loop/route it properly, and when he dropped the tank into place the harness got crushed. I don't know -- I'm just thinking out loud. If I try hard enough I can imagine ten different possible causes for what I saw on my bike. Perhaps my experience was one in a million rather than indicative of a trend.
Old 20th June 2007
Thumper74 Thumper74 is offline
Thumper74 is an unknown quantity at this point
When I was buying my 07 Custom, I had picked out a Pearl white w/o security system. They got it down stairs from the third floor, we did the paperwork, put the tags on it and they fueled it up. Bike wouldn't start. The fuel pump was bad with .2 miles on the odometer. The F&I manager came out and put me on the two tone custom that I had been eyeballing for the same price as the white bike. So far I'm happy and Helen (the sales lady) made sure to put a Freedom bell on the bike for me
Old 20th June 2007
soto1994 soto1994 is offline
soto1994 is an unknown quantity at this point
Default Fuel Pump Failed
I have a 2007 Sportster Custom with the failed fuel pump at 225 mile. Tomorrow will be a week since the HD shop had it. They hope the new pump will be in by Friday. HD should give us something for the inconvenience.
ASOTO
Old 20th June 2007
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
Originally Posted by btkicker View Post
Great work MWD!
Might be a service bulletin but i don't think theres no way its gonna be a recall.
