0 2017 Headlight in 1991?
Last Post: vt883
0 WTB 67698-81D Headlight Assembly
Last Post: vt883
0 My Patriot Defender Knock-Off
0 New Sporty in Dallas, TX
0 Sportsterpedia Progress
4 Scared for my rod bearings after cam removal...
Last Post: farmall
5 WTB / ISO: Mid Controls for Frame-Mount Evo (2001 in my case)
Last Post: racemoto
0 exhaust or cams?
0 Bendix / Zenith questions
Last Post: farmall
0 Ohlins sell to Tenneco
Last Post: Reverend G
5 WTB / ISO: Riser, relatively low handle bars, speedometer mount
Last Post: racemoto
Last Post: Scott
0 35mm showa damper seal rings???
0 Cutting drag pipes to use OEM type mufflers...
Last Post: DirtyHarry68
5 Jiffy Standing
5 Eye Protection When Riding?
Last Post: clif02
0 Harley-Davidson Sportster: Merging The Modern With The Timeless
Last Post: Caustic Dick
0 New handlebar wiring harness 81XLH?
Last Post: owlsplace
0 If you could only have one bike, would it be a Sporster?
Last Post: clif02
0 Wire gauge for solenoid
Last Post: LenC
0 Ceramic Coating My Paint
RLAnderson (58), boomer (53), ESCOBAR (47), davenjeip (46), BLOODYKNUCKLES (43), Shudabenz (40), Sporre96, 071200low (35)
Old 15th July 2007
DG_Sportster's Avatar
DG_Sportster DG_Sportster is offline
Sportster/Buell Model: 1200 Sportster C
DG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to behold
Default WTF? Why is my IAC cycling when the bike is off?
Here's a strange one.....
If your familiar with injected Sportys, you know that when you cut the key or kill switch off, you get a gurgling sound from behind the air cleaner. No biggie, i assume this is normal.
Now imagine my surprise when i came out yesterday to install my shocks ( key still in the house ) a full 48 hours after it had last ran, and the bike is sitting there making this same noise every 20 seconds or so! After a few minutes it quit, but i decided to investigate.....
...and that's when my red-flag-o-mater went up! This noise is, in fact, the Idle Air Control motor cycling from full open, to close, to full open again when the engine is killed. As i said, the noise occurring when killing the engine is undoubtedly normal.
What doesn't seem "normal" is having this event happen with the bike off, and not having been touched for 2 days! No, the ignition switch wasn't in "ACC" either.
I can't see why Harley would program the HDSFI to do such a thing, yet at the same time, i can't see anything but a bad ECM causing such a thing, yet the bike starts and runs just fine.
Is my bike possessed?
Calling the dealer resulted in ZERO info....they had never heard of something like this ( go figure ).
If someone out there has the injection service manual, you sure would ease my mind if you told me this was normal behavior for H-D injection.
Much thanks for any info someone might have.
Old 15th July 2007
LilHog59's Avatar
LilHog59 LilHog59 is offline
Sportster/Buell Model: Nightster XL1200N
Sportster/Buell Year: 07
LilHog59 is on a distinguished roadLilHog59 is on a distinguished road
Whenever I shut my bike off, I always hit the kill switch first and then the ignition key second. I was told this when I purchased the bike by the mechanic delivering and explaining the controls and operations. I have never heard of the sound that you speak of when I shut the bike off, I get no gurgling sound or maybe I just can't hear it. I would take it back to the dealer and get it checked out.
07 XL 1200N Silver/Black
Stage 1, TFI, No More 02's
Rush 2" Slip On's
Taxes Paid, Mabel Is Able...!
Old 15th July 2007
Muttley's Avatar
Muttley Muttley is offline
Other Motorcycle Model: Triumph Bonneville
Other Motorcycle Year: 1973
Muttley is an unknown quantity at this point
Can't state chapter and verse (without digging the manual up) but I saw a statement to the effect that you should ALWAYS shut the engine down using the run/stop switch before turning the key off.
And no, I can't recall hearing any gurgle.
That said, I can't imagine that changing this order would cause the thing to cycle on and on.
Old 15th July 2007
Krayven Sumhead Krayven Sumhead is offline
Sportster/Buell Model: XL1200C (Heywood)
Sportster/Buell Year: '05
Other Motorcycle Model: Ultra (T-Bagger)
Other Motorcycle Year: '03
Krayven Sumhead has disabled reputation
Weird things start happening if the 'kill' switch isn't used.
Old 15th July 2007
Facade Facade is offline
Sportster/Buell Model: XL883C
Facade is an unknown quantity at this point
I never mess with the kill switch, ever. Never needed to on the Buell, the old sporty, or the procession of other bikes I've had in the last 25 years. It is for when you crash, not daily use.
That "warning" was also in the carb version manual.
I just assumed it was to do with safety, stopping the engine whilst you still have your hands on the bars.
I can't believe that HD's wiring is so dodgy that you need to switch it off twice!
Old 15th July 2007
rishnack's Avatar
rishnack rishnack is offline
Sportster/Buell Model: XL1200R,
rishnack is an unknown quantity at this point
i usually always use the kill switch, but have used the key instead before also
and ive never heard a gurgling sound, and theres no reason to have it still breathing when its dead (ignition off)
yes your bikes possessed, i,ll perform an exorcism soon, HD charges for this but mines free.
you dont have Gremlins you have Demons!
2007 1200R
V&H SS & Tuner
K&N Breather
OIL COOLER etc.
Old 16th July 2007
bell883c's Avatar
bell883c bell883c is offline
bell883c is an unknown quantity at this point
Ditto, The kill switch on the injected sporty's is really like the power switch for the fuel pump, it says right in the owners manual to first turn on the key then turn on the kill switch. Same goes when shutting down, first the kill switch, then the key. Why Harley made it this way is beyond me, but a lot of things they do don't make any sense to me. I've never heard a gurgling sound either.
Old 16th July 2007
doxbike doxbike is offline
Sportster/Buell Model: FatBob
Sportster/Buell Model #2: all gone 1200R
Other Motorcycle Model: Honda ST1300;Goldwing1500
Other Motorcycle Year: 0407
doxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of light
Cool
ditto here
All HD's gone now-Riding a Triumph Tiger 800xc and a Goldwing-time's they are a'changin'
Old 16th July 2007
Perhaps it would be better to describe it as a sound similar to an injector firing. It's very faint....
I want to make it clear that it's not the noise when shutting the key off that concerns me....it's always done that once. It's the fact that it seems to do this repeatedly when it takes a notion...with both switches off!
An update of sorts....
On the suggestions above, i went out to the bike yesterday ( which had not been fired for 24 hours at that point ) and, with the ignition key not even in the bike ( i checked to be sure it was in the off position ), i flipped the kill switch on the bars to the "off" position. Imagine my delight when this event seem to set off another round of IAC cycling. I tried everything....starting the bike, and THEN killing it with the run switch then cutting the ignition off....rocking the kill switch back and forth....etc.
This session lasted for approx. 30 minutes, but i might have stopped it myself...
Truth be told, i was timing the whole thing to see how long it lasted, as a nice round number of minutes might indicate this was intentionally programed in by HD, stupid as it would be. Right around the 30 minute mark, i was looking inside the left cover where the fuses are, and I noticed some sort of oxidation looking build-up which my be dried soap from washing it. This lead me to poke and prod, and while tapping on the two relays, the IAC cycling suddenly stopped. As to weather or not this was due to my actions, or that fact that these little episodes last exactly 30 minutes, i can't say for sure.....
Honestly, this is starting to look like an electrical issue...and you know what kind of nightmare those can be, especially for the idiot mechanics at the dealer.
I'll try and duplicate it again today.
Anyone got anymore info?
Much thanks to all.
Old 16th July 2007
chrishajer's Avatar
Sportster/Buell Year: 1988
You had me up until "idiot mechanics at the dealer."
Good luck with your problem.
-Chris
