0 sporty
0 A different Oil filter test
0 Tacho Ratio's
0 Replacing Stock Sealed Beam Headlight in my 1991
0 Air Filter Soaks With Gas
0 Gotta Start a Thread for the Streetfighter Too!
Last Post: 83XLX
0 1980 Sputhe Sportster
0 Supertrapp exhaust too &%$#in loud!
Last Post: themadone
0 Forum problems???
0 1987 XLH1100 Gas in Oil tank
Last Post: rebel7
0 Hello from the Netherlands!
Last Post: khav
0 Khk flywheels in my ironhead....timing
Last Post: vonhatch
0 Cv carb jet question
Last Post: Bob F
0 Harbour Freight jack
Last Post: Bob F
0 Safety Announcement; Re: Saint Patrick
0 900 dual carb front head
Last Post: Bryan83taco
0 Replace crank bearings
Last Post: Maxdog2
0 VOES Switch on CV carb conversion.
Last Post: BlackAce
0 HD 100th Anniversary Sporty Pic Thread
Last Post: MoneyFor
0 LED turn signals problem?
Last Post: Scuba10jdl
drifter44 (75), Streak70 (71), Rayzer (61), ridefree1 (57), erk (53), LOBO (51), motley79 (40), polaris0352 (38), TManos916 (38)
  #201
Old 27th January 2015
wkong's Avatar
wkong wkong is offline
wkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to all
Bumping it back up! Horrible corrosion all over the fuse block. Blasted it with some cleaner, loaded up new fuses and relays with grease, and boom. No more issues starting. It seemed that most people's system relay was going first, but my fuel pump relay went first. It would crank and crank and crank and never get enough fuel sometimes, and then out of nowhere viola, starts right up. Wondering if the previous owner was having problems and couldn't figure out why, which might explain why an otherwise pristine bike with under 10k miles was going for so cheap.
Just to help those using the search function... bike will crank but won't start.
sportsterdoc's Avatar
Every 2007-2009 model should have fuse blocks and relays examined regularly.
Old 28th January 2015
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
The system relay controls the fuel pump.
There are two identical relays:
1. Main/system that controls the fuel and ignition systems.
2. Starter relay that controls cranking.
So what happened is the system relay finally closed.
Old 1st June 2015
rockmanbm's Avatar
rockmanbm rockmanbm is offline
Sportster/Buell Model: XL883 Low
Other Motorcycle Model: CX500
Other Motorcycle Year: 1979
rockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nicerockmanbm is just really nice
I believe mine is doing this now as well. I will be stripping and cleaning the fuses and relays tonight. Glad this forum is here to give appropriate info
Road Name: TANK (2009 XL883L ridden hard daily)
Old 2nd June 2015
Bone's Avatar
Originally Posted by Bone View Post
No but it took 4 years for the untreated relays to fail on Jenn's bike, as did it on Nytstr's bike. So it is quite logical/likely that it would take at least that time before it might occur again, probably longer with the grease.
Obviously YMMV and others might vary because of differences in usage.
Thought I'd report back, here we are another 4-5 years later and I was just in there finally replacing the stock battery.
While there I spot checked the relays and there's little or no new corrosion. The replacement relays still look fine.
Old 2nd June 2015
rockmanbm's Avatar
That is good to hear. I will be tearing into mine and cleaning the entire fuse box, replacing fuses and relays on my 2009. Looking back on it, mine has been having problems over the last 2 weeks with intermittent starting issues, and the IAC started cycling while off. Anyone been able to source some good relays that are sealed?
Old 12th June 2015
rockmanbm's Avatar
I was able to clean corrosion off and the bike worked flawlessly. I wonder of a '10 fusebox is sealed better and will fit on a 09
Old 12th June 2015
Different animals
Fuses 2007-2009
Spare
Instruments o
Ignition g
Battery bn/gy
Lights be
Accessories o/w
P&A ignition fuse
Spare
ECM be/gy
Fuel pump o/gy
System relay
Start Relay
Spare
Fuses 2010-2013
Ignition g
Battery bn/gy
Lights be
Accessories o/w
ECM be/gy
System relay
Start Relay
Old 12th June 2015
Bone's Avatar
Yes, 10 is sealed better, cause it's a complete redesign.
No, not compatible.
Old 1st January 2016
Ultrarunner Ultrarunner is offline
Sportster/Buell Model: XL883C
Other Motorcycle Model: FLHX
Other Motorcycle Year: 2007
Ultrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud of
I have an 09 883c, and have finally resolved this issue. Without going into the entire back story, I purchased this bike in August, and have put 6000 miles on it since. It was garage kept and immaculate (until I got my hands on it....), with 5000 miles on it, and I doubt had ever seen water.
I started having battery drain issues about a month ago, and replaced the battery, as I figured it was original. Put an HD battery in it, which was fine for a couple of weeks, when I started chasing potential issues. Turns out the new battery had a bad cell. So, HD gave me another, which was dead the following morning.
I had already seen and read this thread, and had cleaned my fuse panel as well as testing my relays. The fuse panel had very, very little corrosion on it. The relays tested fine (with multimeter, not just a click test). Charging system checked out fine, I had already gone through wiring off battery with a fine toothed comb, and was getting frustrated.
I put in new relays, just in case.... that was 4 days ago, and it solved the problem. Even though the old ones tested fine, there was one that must have been working improperly intermittently. Argh. Very aggravating. So, I will be cleaning the fuze panel with every oil change as well as keeping a couple of spare relays in my tool kit. Pretty cheap insurance.
Of course, while working on this my FZ 1 fuze block arrived, so I'll be installing that soon. Glad I figured out the charging issue first! Thanks to the forum- this is a great resource.
2009 XL883C
