Last Post: cazz1000
0 tire time
0 nice ride today
0 Grenade plate
0 Whats your carry gun?
0 Movotor Smoked Tail Light and Turn Signal
0 Battery issue?
0 First run
0 Dynojet Power Vision 2
Last Post: Turbo Sporty 48
5 Favourite grips?
Last Post: Hellbent_4
0 49mm Forks?
Last Post: Redbeard2
0 Larger Roadster tank for 79-81 Sportster
0 Friction modifiers in gasoline
0 Asgardian Prep for Labor Day weekend in the Keys
0 A MG midget driver tried to kill me today.
Last Post: BSA Bob
0 Trouble codes
Last Post: DFuller1980
0 Bigger valves
0 Power Loss At Sustained High RPMs
0 Copper vs Iridium Spark Plugs
0 ironhead xlh 82 oil problem
Last Post: owlsplace
0 Clutch cable oil leak
Last Post: Truckedup
0 1st offering to forum then open market
0 more flow = dirty air?
Wizwill, ron bolen (71), mustangt5 (55), Harley (54), wally509 (51), pperrone (48), Rapha (43), chadp (40), Randum77 (40)
Old 14th October 2007
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
And yes it is covered by warranty.
Old 15th October 2007
Originally Posted by 2007Low View Post
Hi, I'm not sure which member mentioned it, it was quite a few pages back in one of these threads about EFI problems. But I think he was right on the money when he said "it's not the fuel pump, it's the fuel pressure regulator that's the problem", which is part of the fuel pump assembly. He also mentioned HD Tech Tip #328 and posted an excerpt from it which fixes the low fuel pressure that the faulty regulator is producing.
My bike was occasionally having a hiccup in the first few minutes after cold start. It also was only getting about 40 mpg consistently, city or highway. Yesterday I went to the dealer and had them install the service kit from Tech Tip #328 and I could definitely tell that it runs a little smoother which stands to reason if the fuel pressure is too low it doesn't atomize as well as when it is sprayed into the cylinders at a higher pressure. When they got done with my bike I filled it up for the 100 mile drive home and my fuel mileage went from 40 mpg to 51.25 mpg and this included drive 80 mph for 50 of the 100 miles that I drove. Jury is still out on the hiccup but so far so good.
Do you have any details about what the parts they installed were for tech tip #328?
I'm very curious. We really don't have much of a stumble...but we DEFINITELY have crappy mileage!
Kev
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Kev - Do you have the tools to check the fuel pressure on your bike? You could just check and see if your getting spec (from memory 55-62 PSI).
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
No high pressure gauges in the box these days, but yeah, I'm starting to wonder.
FOLLOW-UP QUESTION for 2007Low...
What oil bag temps were you seeing before and after the fix.
Old 16th October 2007
2007Low's Avatar
Hi Kev, sorry I can't give you temps, don't have a gage. There is a p/n for the kit they put in my press reg, check out this thread, oops this website won't let me post another URL, I'm too new, anyway I went there and got the kit p/n, here it is, 61005-07 this will be under warranty if you can get them to put it in for you, my dealer did.
Unfortunately poor weather here in Minnesota, won't be able to ride for quite a while it looks like.
Started the bike an hour ago to see how it acts on another stone cold start and it still stumbled one time. I waited about one minute before I gave it a little rev and as I said it did cough once. Just curious, aren't these bikes supposed to run on a fast idle when doing a stone cold start for the first few minutes? Mine doesn't, it hunts just a little but just barely noticeable and seems to be running at a pretty normal idle speed. Wonder if the ecm needs remapping after fixing fuel pressure, I know they need it for airfilter and muffs? Thanks
You know what, I'm gonna start a separate thread for this conversation, please check it out.
http://xlforum.net/forums/s...998#post928998
Old 2nd October 2008
sirbOOm's Avatar
sirbOOm sirbOOm is offline
sirbOOm has disabled reputation
Shouldn't the damn bike just work? Haha!
Old 17th March 2009
dr.feltersnatch's Avatar
dr.feltersnatch dr.feltersnatch is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 08
Sportster/Buell Model #2: Xlh
Sportster/Buell Year #2: 77
dr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud of
Originally Posted by whittlebeast View Post
Suck, Squeze, Bang, Blow, Suck, Squeze, Bang, Blow ..... and all at the right time.
AW
I dated a chick like that once
"A man dies when he does not stand up for what he knows is right"
Old 17th March 2009
Just ONCE - bummer...
Old 29th May 2009
supersport supersport is offline
Sportster/Buell Year: 1965
supersport is an unknown quantity at this point
Default big twin evo forum
do you guys know of forum need some help on efi no start.. have some thing to ask thanks
