Snippets
7th January 2016
Posts: 1,658 Sportster/Buell Model: XL Sportster/Buell Year: 1992 Sportster/Buell Model #2: 1978 XLCH project Other Motorcycle Model: Sportster XLH Other Motorcycle Year: 1975
1978 XLCH magneto conversion
I've been looking at my recently acquired 1978 XLCH and the ignition switch is worn, wiring is pretty ratty, and the battery is fit for nothing.
I do have a magneto available, and I was wondering what is involved to fit it? seems to be either a matter of finding an older cam cover and related cam gear, or an adapter fitting into the nosecone hole.
Anyone have any particular thoughts on this?
7th January 2016
Bike Builder
Posts: 1,813 Sportster/Buell Model: xlch Sportster/Buell Year: 1973 Sportster/Buell Model #2: xlch stroker Sportster/Buell Year #2: 1974
Go for an early cover...they make a tach drive setup tho I'm not sure if 78 still has the hole in the cover either way don't go that route I and another member have both had issues with them and we both went to the early cover and wish that we had just bought the early cover in the first place...
"ya...i saw a guy do this once... " -DR DICK
7th January 2016
Bike Builder
http://xlforum.net/forums/s....php?t=1916105
Here's the link to his thread...mine didn't go as bad as his but I cought it sooner because of his experences
7th January 2016
Ha ha, oh wow, I'm not even going to LOOK at all that shit.
Mag can go on the 45 as originally intended. Wiring is a pain but not expensive, I'll fit a plain clutch lever and wire horn and headlight flasher to the right-hand side pod. No indicators, the bike doesn't presently have them and a 1978 model doesnt need them in UK. No electric start, because the bike doesn't have one anyway. Batteries aren't cheap but they are just a thing you have to have.
Ok, press on.
7th January 2016
Bike Builder
I think ur bike came wit q grind cams (not sure wat year they started that)so your gonna want a set of early p or pb (p was stock)to run with the early cover but that's basically all that needs to be done to mount the mag
I think toward the end of the thread I posted he shows pics of the mounting a small bit needs to b ground from the mag adapter to clear the Vin block
7th January 2016
Posts: 14,284 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
Q cams didn't begin until 1980.
7th January 2016
Posts: 64 Sportster/Buell Model: XLCH Sportster/Buell Year: 1972
Here is my answer to using the tach drive mag...
7th January 2016
Bike Builder
Thanks Bruce I wasn't sure...and lucky I figured you'd show up soon after reading the title
7th January 2016
Posts: 1,077 Sportster/Buell Model: xlh Sportster/Buell Year: 1975 Sportster/Buell Model #2: 84 xl paughco rigid Other Motorcycle Model: 70 xlch
Pinion shaft changed in 77 early cam cover won't fit
7th January 2016
good catch,Mike.if you wanted one really bad,you could swap the pinion shaft,but that's alot of work!
