Last Post: ronccc
0 OEM Headlight Bucket?
0 Year help on ironhead confused
0 Removing Rear Shock
Last Post: slamtry
0 keihn setup at Altitude
0 Boardtracker Project
Last Post: Ultrarunner
0 New from Ohio
0 Missippi Gulf Coast here.
0 Identity crisis
0 Pinion shaft roller bearing plug fit
Last Post: xraytoken
0 Fork Oil Measurement
Last Post: Cyclone14
Last Post: Desertfox
0 NRA files for bankrupcy
0 Who runs (or has run) a Barnett Scorpion Clutch?
Last Post: Scott
0 Newbie seeks smoother ride
Last Post: 45Brit
0 Carb Air Vent hole cracked
0 63 XLCH revival
0 My Wife Says …
0 Handlebars
Last Post: Dr3wDrop
0 Please School Me On Carbonite Clutches
0 mississippi queen video
0 motorcycle on lift for two+ years
Last Post: Akdawg
0 my sunday driver...
Last Post: 84rzv500r
0 Rebuild a 2 stroke in 9 minutes :)
steve yorke (63), edman (55), Hudsonator (53), kozman32 (53), R3DN3X (51), gmcsid (50), mitch (45), Txngrg87 (34), Gotenfan (31)
Old 11th August 2018
doodah man's Avatar
Originally Posted by spamer80 View Post
Hippysmack, thank you, seems like DIY is still the best option out there. But I also found this:
and it seems far more practical. But the J&P says it still only fit 1972–1976 years. I`m not sure it the size was the same in 82-85.
Rodzilla, yes, I`m 100% sure that I prefer to keep these stock ones.
For the fitment, 72-76 chain inspection plug has a vent hole and some type of gauze filter to vent the trans/primary, where 77 up vent the trans through the top rear of the case. I don’t believe that the thread pitch and diameter changed, so technically you should still be able use them.
Old 12th August 2018
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Yesterday the clutch cable broke off. Unfortunately noone have replacement here. Plan to buy one from ebay. Is it possible to change it without removal of all primary cover?
Unfortunately, no. The primary cover has to come off to change the cable. Make sure you have a shop manual or a good description/video of how to remove it, what to look out for, and how to adjust the clutch after you put it back together.
spamer80 spamer80 is offline
Sportster/Buell Model: XLX1000-61
spamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to all
I put Russell drilled stainless rotors and EBC Kevlar pads on the front brakes of my '83 and that improved the braking. It's still not one-finger braking like on Japanese bikes, but it's good enough for me.
Your bike seems the same as mine. Do you still have stock exhaust? How does it looks inside and is it quiet? I`m not sure which will be the best option to make it as quieter as possible - to buy or diy baffles or buy completely new mufflers?
Old 13th August 2018
83XLX's Avatar
The stock exhaust system is relatively quiet, but not as quiet as those on newer Harleys. Looks like you have the stock exhaust - hold a muffler up and look through it. You shouldn't be able to see any light through it if it's still stock. If stock, you won't find any mufflers that are more quiet that don't hurt your performance. Here's a full picture of my XLX.
Looks good. No, I can clearly see through my exhaust pipe, there is nothing at all inside. And I completely do not give a xxxx about perfomance. I'm all year and all weather rider (at least I was) and for me the quieter and SMOOTHER bike is - the better.
I also plan to install efm clutch and relocate the rear brake to left handlebar. Far more control in deep snow or ice.
83XLX's Avatar
In that case, find some stock take-off mufflers and put them on. Look for ones with the same mounts as your stock ones (front muffler has the mount on top with a built-in brake pedal stop, rear muffler has a mount on the bottom). Mufflers from 1982 well into the Evo era will work, so finding a pair of them shouldn't be too difficult.
Great. Thanks. I thought so, that the mufflers looks like from Evo, but still was not absolytely sure. Just need to repaint it to black then.
Old 14th August 2018
Evo mufflers should work up to about 2003.
83XLX's Avatar
True, but I think the last year with the integrated brake pedal stop was 1995. The mufflers from 1996-2003 will still fit, but a brake pedal stop will have to be added.
Cycle Shack used to have the brake pedal stop as a separate orderable part. There is no HD part number for it as it was a welded on part of the muffler, not a separate part. I do not know if there is a current after market part?
My indie mechanic made one for me for my 1980...
