Keep & Kill
Battery
Last Post: Andy56
1 Week Ago
Posts: 235 Sportster/Buell Model: XLX1000-61 Sportster/Buell Year: 1983
Long time no news, sorry. Looks like the bike is fully tested in winter conditions and doing great. The auto clutch works perfectly smooth, making snow and ice riding easier.
The problem was in carb. After some miles it was starting to run very rich. So much the bike could not handle any rpm below 3000. The problem was solved - culpit is Dynojet thunderslide emulsion tube. It has only two tiny holes and after some run it became clogged with ice resulting no air going to the main jet.
Installed stock emulsion tube and now everything is perfect.
01.02.2021 - 43 miles run - 30F
01.12.2021 - 52 miles run - 5F
1 Week Ago
Posts: 1,165 Sportster/Buell Model: XLH Sportster Sportster/Buell Year: 1991 Other Motorcycle Model: 650 Triumph Bonneville Other Motorcycle Year: 1970
for my mufflers I used exhaust adapters for a car I crushed the small dia to a star shape making it a lot smaller. then drilled the small dia behind the crushed area up the the major side of the adapter that fit nicely into my mufflers.
I drilled holes all over the smaller dia.
I wrapped the adapter with a muffler wrap to quiet it down and drilled a mounting hole on the back side of the muffler to hold it in welded a nut into the adapter to screw the bolt into.
I found what even worked better yet was when I added vanes to swirl the exhaust out.
it was seat of the pants much better throttle response
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
1 Week Ago
Posts: 700 Sportster/Buell Model: XLCH Sportster/Buell Year: 2003 Sportster/Buell Model #2: Cyclone Sportster/Buell Year #2: 2001 Other Motorcycle Model: FXDC Other Motorcycle Year: 2013
Man-how do you ride in that weather?
My hat is off to you!
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertrap 2/2
1 Week Ago
Thnx. Carefully  Actually the worst is to get out from garage. About quarter mile of that on 1st pic. And get back after ride. Other things are no deal then. But I need to buy handguards to deflect wind. The fingers become insensitive after more than 10 minutes ride at 60mph and above.
1 Week Ago
Posts: 1,051 Sportster/Buell Model: XLX Sportster/Buell Year: 83 Sportster/Buell Year #2: xlh
up here in the mountains we get some snow during the winter.not as bad as you,hahaha,i use ski mittens,really keeps my hands warm.screw those heavy duty gloves.they don't work for me
1 Week Ago
You guys make me feel like a wimp.
Geez.....Gets 55* here and I don't ride
1 Week Ago
Definetely a good advice  I've thought about it but since I'm kind of lazy and short of money, like handguards I decided to delay it and delay and delay...oops, winter?!
1 Week Ago
Posts: 32,522 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
National Cycle brand for the hand deflectors
Snowmobile mitts [No!, you do not need finger gloves!]
Snow pants, like the kids wear only for adults  [ski pants?]
Ensure that footwear will fit around the shift and brake pedal arrangements
My coldest ride at -11`C
Typical winter at +5 to -5.
1 Week Ago
Posts: 14,936 Sportster/Buell Model: XL1460C Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL1200R Sportster/Buell Year #2: 2006 Other Motorcycle Model: XL1200R Other Motorcycle Year: 2004
I’ve also learned that “loose” clothing promotes better blood flow and will keep you warmer longer. My Achilles heel are the extremities, feet and hands. Good cold weather boots help a lot but don’t generally fit under shift levers. I learned how to shift with a cast on my foot and transferred that lesson to the heavier boots. You simply shift using the edge of the sole, with practice it becomes second nature.
1 Week Ago
Ski pants working great, always using them. And about footwear - my brake is on the handlebar  Makes choise wider. I still prefer winter army boots.
