0 New from France
Last Post: 4schizzle
0 2021 HDs now Out!
Last Post: Mr Dream Merchant
0 Zippers 1250 kit
0 75 IH Oil leaking into starter from primary side/ bendix
0 XL1200 03 changing from 29tooth to 27
0 '14 Sportster Coil Leads Question
0 Improving Fuel Mileage
0 Sportsterpedia Progress
0 windshield on a Custom
0 Any experience with REBUILT title?
Last Post: canoli
0 Boardtracker Project
0 Clearance between clutch faces 1974 transmission
0 Motorcycle airbag jeans
5 Tire Pressure?
Last Post: sleighcrane
Old 2nd November 2020
staniel's Avatar
staniel staniel is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: XL1200CX
Sportster/Buell Year #2: 2019
staniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to all
Default Drum brake rod interferes with hardtail frame
I'm trying to build a 1971 XLCH chopper and I mocked up the rear wheel this weekend.
When the wheel is lined up in the center of the frame, the rear brake rod wouldn't be able to mount to the drum - it interferes with the frame. See the picture below:
https://ibb.co/pvrqrhD
What are some ways around this? I was thinking I could flip the lever arm upside down (180degrees) so that the brake rod would be below the axle instead of above, but I read some forum posts advising against that.
What are my options?
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
That’s a cable set up rear backing plate.
Old 3rd November 2020
Tim The Grim's Avatar
MetalWorkingXLFan
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 97
Yup, that’s a cable type backing plate.
If you insist on a rod...This is what I did before I switched to a disc.
It’s kinda overkill but it worked.
kitabel kitabel is offline
Sportster/Buell Year: 1989
If you flip the lever it will work in compression, and must be much stronger.
doodah man's Avatar
Also if you flip it and reverse the action, you need to file the brake cam down correctly or risk locking the rear brake up.
sportsterdoc's Avatar
Nice work!
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
I flipped the lever down and ran the rod low. Doodah is right about rounding over the "corners" on the rear brake cam.
When life gives you lemons, make orange juice--
and let everyone wonder how you did it.
Bigshankhank Bigshankhank is offline
Sportster/Buell Model: Ironhead Hardtail
Other Motorcycle Model: KTM Duke 390
Other Motorcycle Year: 2015
Bigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant future
As others have said, you will want to pull the brake cam and file a bevel on the squared edges, otherwise you risk the flat sides "locking" between the brake shoes and subsequently locking the rear wheel.
the brakes on these machine were in the shinola department. sure they would slow down but lock up at speed was near impossible on a good surface, lower speeds yes. i could stand on mine and lock up was probably around 25mph. only fix was aggressive materials and more drum wear.
however, i can see the point with the cam. only other way is to run close tolerance and limit travel. shoe and drum need to be right on or you will get grab/release syndrome.
Old 4th November 2020
staniel's Avatar
If I were to get a different backing plate, do you think the rod would clear the frame? Or Do you think that I'm pretty much stuck to using a cable because of the shape of the frame?
