Last Post: Bow only
0 2021 2nd. Annual Midwest M&G
0 first xlch
0 Forest Lodge & Campground Mairenville, Pa.
0 engine backfires and sputters
Last Post: mwXL 2006
0 Improving Fuel Mileage
0 2021 HDs now Out!
0 The KTM Duke That Started it All
Last Post: sprink
0 hmmm, whaddaya think? (Footpeg Location)
Last Post: 45Brit
Last Post: bklyngeezer
0 Check this one out for sale in the UK
0 1999 S upgrades
0 1977 Shift shaft
0 Xl 1000 1979
Last Post: Andy Hog
0 my sunday driver...
0 Cutting out at WOT
0 OEM Headlight Bucket?
0 Flat Tracker Pics
Last Post: Gary E
0 Tires & Shocks Needed: '90XLH 883
Last Post: Rollbar
0 New guy out of AZ.
Last Post: 1r0nH0g
0 V-Twin Solo Seat Plunger Kit
Last Post: fernf5
Steph (55), yubman (50), Sporty1971 (50), Windesch (48), Mark_Bench (44), motherduce (42), sgtfry (39), Mrtechit101 (30)
Old 4th November 2020
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
I don’t believe there is much difference in the backing plates other than the added lug for the cable actuation. Although I’ve never compared. I do have about 60 backing plates of all years which I could compare this eve when I get home. However, I think the simplest solution has been mentioned a few times in this post. I would suggest heeding the pivot chamfering if you go that route.
You could always adapt a disk/hyd set up.
Old 2 Weeks Ago
staniel's Avatar
staniel staniel is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: XL1200CX
Sportster/Buell Year #2: 2019
staniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to allstaniel is a name known to all
Does the cable driven brake require a different cross shaft? My manual (Clymer 1959-1985) doesn't even mention any drum brakes post 1978 so it only shows brakes with rods, not cables.
I can find very little information on this type of brake set up on the internet.
Old 2 Weeks Ago
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
You would have to manufacture a retainer for the cable end at the pivot arm or convert to a disc
or adapt a 79 and later brake lever to the forward control
click to enlarge
mikethebike61's Avatar
Unless you go to a disc I'd swap the cable for a shaft unit and fabricate the rod...damn site easier than fabricating the cross shaft
