Battery
Last Post: Andy56
3rd December 2020
Blind Owl
Posts: 6,302 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
Originally Posted by fernf5
Speaking of carbs-the 68-69 Tillys have a ball valve in the accelerator pump circuit. My carb kit replacement diaphragm didn't have one. Guess it was an improvement? Are these available anymore?
The Tilly's were available on lots of things for many years and most parts are still out there. Google is your friend.
Also, research "pop off" pressure while your doing it. It wasn't correct from the factory and a little effort will bring big benefits there.
3rd December 2020
Blind Owl
If you have already had the engine running there's probably no reason to pull the top end just now.
You have just honed the bores with the rust that was in there and if the rings didn't stick unless your prepared to bore and install new pistons it's probably going to be "as good as it gets".
I know the feeling. It's hard to stop yourself (impossible ?) from just wanting the reassurance that the thing will run and be what you want it to be.
So, for a brief moment you felt like you were 18 years old again ?
(Don't worry, we are all chasing that dragon here)
3rd December 2020
Posts: 83 Sportster/Buell Model: XLCH Sportster/Buell Year: 1968
The reason I tried to run it was to see IF it would and then I couldn't put it in neutral with any throttle on. No clutch. No throttle, it died. What a pickle. Oh well it will run soon enough. As far as feeling 18, I always feel like I'm 18 ... in my head
SW WA 1968 XLCH
4th December 2020
Blind Owl
Boy your lucky.
I'm only 18 for about 20 minutes at a time. More or less depending on how many laps we're doing.
4th December 2020
Posts: 11,032 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
The best piece of mind you could give yourself would be from removing and inspecting the transmission. Welcome to the forum!
4th December 2020
I have the clutch completely removed, so I'm right there. Few more bolts and she's out? I can look for obvious wear but I'm in unfamiliar territory otherwise. Gearboxes aren't my strong suit. I'll have to study the FSM to see what's involved....
Found an old ugly scar when I opened the primary. See the screwdriver pointing to it.
4th December 2020
Boy your lucky.
Yeah, now if I could only talk the rest of me into feelin 18!
4th December 2020
I'm more concerned about the short studs on the chain tensioner, than what appears to be a good repair.
4th December 2020
Interesting nylon primary chain tensioner too. Yes, a few bolts for the trap door, and a large nut holding on the right side sprocket on. Grab the clutch gear with your left hand, and give the main shaft on the right side a few raps with a rubber or rawhide mallet and it should pop right out. Post pics!
Another fun thing to check is the flywheel rim through the timing inspection plug hole. If you find a series of numbers stamped into the rim, you might have a set of stroker wheels hiding in there.
4th December 2020
The nuts are only on a few threads. Just my way of keeping track of em.
