Last Post: ronccc
0 New sportster in HD Research Survey
Last Post: Mr Dream Merchant
0 2021 HDs now Out!
0 Cutting out at WOT
Last Post: phyhowe
0 Can I fill gas tank up to top?
0 1977 Shift shaft
0 Zippers Hammer 99 kit Info
Last Post: 11B40
Last Post: skien
0 83 XLH w/Velorex 562
0 Motorcycle airbag jeans
0 Reflectors...Yeah, or Neh
Last Post: Marsikus
0 Boardtracker Project
Last Post: JonesL
0 Flat Tracker Pics
5 Tire Pressure?
0 Battery
Last Post: oldboy
0 XL1200 03 changing from 29tooth to 27
0 2021s getting new MT22 ECM
0 Rear Sprocket Runout
0 75 IH Oil leaking into starter from primary side/ bendix
0 Improving Fuel Mileage
Last Post: LLOYD883
0 New guy here from Michigan
Last Post: bklyngeezer
0 Mustang 1 Piece Seat 6-XLS
0 V-Twin Solo Seat Plunger Kit
Last Post: fernf5
Reynoldston (80), showmebandit (67), Hoppy1313 (67), FredrikK (65), Toejam503 (65), YO MUDA (62), Altopass (61), tim 2007xl1200c (54), w9awx (48), 3xtrastout (42)
Old 21st December 2020
shgrier's Avatar
shgrier shgrier is offline
Other Motorcycle Model: 116" S&S FLSTFB
shgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the roughshgrier is a jewel in the rough
Default St. Andrew(s), save my tranny!
Good evening folks, and happy holidays!
I'm taking some time off to tear into Blackie's transmission and replace those three troublesome stock gears (CS 2&3, and MS 3) with the Andrews gears. Swapping them out was a breeze, and now the arduous task of shimming. Fortunately, I've found a local source (if you consider Tacoma local) for the shims, so I don't have to order, then wait, then install, then find out I need different sizes, then order, then wait, then install, rinse and repeat...
I have a few questions, as fortunately, it looks like the only gear that's out of tolerance is the Countershaft Low gear. The inner shim is already as big as is available as a Harley part (.100"), I need another 15-20 thou. Is it acceptable to put two shims in this location to get me to .120"? I would then have to get a slimmer shim for the outer Countershaft Low gear (currently at .070" - would go to .055 or .050").
Secondly I'm wondering about my clutch gear and my 2nd Gear Mainshaft (see pic).
The face that mates to the clutch gear seems worn, but there's nothing to wear that face except the face of the clutch gear, and that couldn't happen because the 2nd gear would be interlocked with the clutch gear.
It's almost like there's SUPPOSED to be a portion of the face on the 2nd Gear Mainshaft that's raised.
When I measure between that raised portion of the face and the dogs on the clutch gear, I'm between .032 and .058", but not if I measure the flatter portion of the face of the clutch gear. The clutch gear looks ok except for some wear on the dogs.
Thoughts on this clutch gear?
Finally, is it acceptable to have more than one mainshaft thrustwasher? The tranny had two in it (both .050") when I pulled it out, but I still get noticeable lateral movement when I check end clearance on the sprocket-end of the mainshaft, so I'm thinking of getting a couple larger ones to take up that slack and get back to tolerance.
Thanks in advance!
doodah man's Avatar
Perfectly normal (and required according to parts manual) to have two shims inside cs low. Not normal to have or need two shims for the main shaft thrust washer. Any gear dogs or mating pockets that are chipped and worn is just asking for trouble. If you have the means, replace them now.
Old 4 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
From your description it seems there is too much distance between both shafts and the cases.
Having to run two shims on both shafts is not "normal".
There is what Harley calls a "thrust washer" in the end of the clutch gear. No one ever touches them.
The clutch gear is located by the main bearing. As long as you have the correct door and the correct bearing the clutch gear should be in the correct position.
This also depends on the trap door seating fully against the case. And that the cases are mated correctly.
Old 4 Weeks Ago
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud of
I know it's expensive but I'd change out everything for new Andrews parts: gears and shafts. Then you don't have to worry about a weak link in the trans that could blow up later causing very expensive damage. Of course, it's not my money but I did this on my '78 and it shifts like butter and was very easy to shim to perfect.
Old 4 Weeks Ago
ferretface's Avatar
Originally Posted by ericfreeman View Post
I know it's expensive but I'd change out everything for new Andrews parts: gears and shafts...I did this on my '78 and it shifts like butter and was very easy to shim to perfect.
+1
Ironhead cases are rare and expensive. I also went all-Andrews, and shimming was a cinch!
Old 2 Weeks Ago
shgrier's Avatar
Thanks for all the replies - Doodah, I did put a second left shim on the 1st gear (countershaft) to get the proper CS3 and CSLow gap in neutral. I'm still not able to get under about .020" CS endplay, but it was WAY worse than that before I started (like .050), so I'm going to call it a win - I'd need a .090 thrust washer, but they only go to .075. I doubt that using 2 TWs would be proper, so I'll live with it.
While I appreciate others' comments about going all-Andrews, I can't swing nearly a grand for such an upgrade - especially after already spending $250 on the three Andrews gears the board recommends be replaced anyway. I did replace the clutch gear and MS2nd per your recommendation Doodah (with OEM gears off flea-Bay).
Other than bad spacing on the CSLow gear, the other thing I discovered was that the Pawl Carrier Support tower wasn't perfectly perpendicular to the trapdoor and parallel to the shift fork shaft. I bought a new tower, but it had the same problem, so I carefully planed down the mounting boss on the trapdoor to remedy that. I also replaced the Shifter Finger Rollers with the older Shovelhead ones. I'm not sure why y'all recommend filing them down so they're the same height as the stock ones - they don't interfere with anything sticking up above the shifter cam like they do. Turns out the ones that were already in there were probably those SH ones anyway, as they were the same height measurements. But they were worn, so it was good to replace them.
I went through the blueprinting thread for the shifter, and checked everything. I put in new Pawl Carrier Springs, and Shifter Pawl Spring (though the existing ones were still serviceable). I also replaced the Pawl Carrier, since the old one looked worn.
Everything's shimmed and spacing is correct (other than the CS endplay as mentioned above). Took her out today for a shakedown ride - a bit sticky between 1st and 2nd (both directions), but I'm thinking the new tower and Pawl Carrier just need to get seated and worn in (though I used assembly lube when I put everything together). I also need to readjust the clutch one more time.
It shifts up and down through all 4 gears, and the 23 tooth drive sprocket sure makes riding at highway speeds more pleasant.
Thanks for the help, y'all - the 4-speed Sportie Transmission is no longer a magic box to me!
Old 2 Weeks Ago
gearhead1944 gearhead1944 is offline
Sportster/Buell Model: k-model
Sportster/Buell Year: 1953
gearhead1944 is an unknown quantity at this point
The stickey 2nd.gear shift is due to the taller finger rollers hitting the tower.
Old 2 Weeks Ago
Blind Owl
I'm not completely understanding your term "sticky". Failing to shift sometimes ?
I wouldn't be happy with 20 thou end play on the C/S. FSM calls for 4 to 9.
That can be tricky to get exactly where you want, but too much will affect your gear spacing.
FSM calls for 38 to 58 which is a 20 thou range but if your plus 11 on the C/S already and your on the wide side with clearances you could well have a problem there.
Old 2 Weeks Ago
Ferrous head,I was refering to OP's post #6.Stickey 2nd
gear shifts.The big twin rollers are taller and going in and out of 2nd gear the roller hits the tower.
Old 2 Weeks Ago
shgrier's Avatar
Sticky as in the shift lever doesn't always come back to center - again, new tower and pawl carrier probably need to wear in. The new pawl carrier springs are much stronger than the old, worn-out ones, so the shifter should kick back into slot easier.
GH1944 - not sure how the additional .020" height of the roller could possibly interfere with the tower - the face of the tower is at least .250" away, and only on the MS2nd, since the CS3rd roller is out past the end of the tower. As I said in my post, the ones I pulled out were the same length as these I put in (one was actually longer by about .002").
FerrousHead - how can i suck up that additional ~.010" when I can't get a shim big enough? - I doubt doubling up on that CSLow thrustwasher would work - it's held in place by the machined recess in the outboard side of the gear itself; the end of the CS is thinner than the ID of the thrust washer at that point of the shaft. Then again, maybe a .025" (smallest size they make) on the inboard of the gear pocket and a .065" outboard of it - there might be enough pocket left to hold the .065 in place?
