0 Flat Tracker Pics
5 Tire Pressure?
0 Battery
Last Post: oldboy
0 XL1200 03 changing from 29tooth to 27
0 2021s getting new MT22 ECM
0 Rear Sprocket Runout
Last Post: Bow only
0 Motorcycle airbag jeans
0 75 IH Oil leaking into starter from primary side/ bendix
0 Improving Fuel Mileage
Last Post: LLOYD883
0 2021 HDs now Out!
0 Zippers Hammer 99 kit Info
0 New guy here from Michigan
Last Post: bklyngeezer
0 Mustang 1 Piece Seat 6-XLS
0 V-Twin Solo Seat Plunger Kit
Last Post: fernf5
0 Any experience with REBUILT title?
0 my sunday driver...
0 1977 Shift shaft
Last Post: 1Scooter
0 New from France
0 Identity crisis
Last Post: Edmundas
Last Post: rickxx
  #91
11B40 11B40 is offline
If I'm not mistaken all of the successful Sportster fuel drag bikes used the stock dry clutch with an extra plate installed. My 77" used the '66 stock dry clutch with a mix of XR750 and Triumph springs. Never slipped. Nobody we rode with used a wet clutch. I consider a wet clutch to be a lazy way out of an easy problem: keeping the thing dry inside.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
and coming out of slow tight corners.i remember hearing them do that.
That was the krappy skinny tires they ran back then, spinning up as the power hit.
Originally Posted by Jeff View Post
Us old Ducati kids wear tee shirts that say "loud clutches save lives". That distinctive dry clutch rattle used to be the hallmark of the make. Now, with increasing power, they've gone wet.
It is very likely the European version of the EPA has had a chat with Ducati regarding their "noise pollution"....
Jeff's Avatar
Jeff Jeff is offline
Sportster/Buell Year: 1976
Jeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to beholdJeff is a splendid one to behold
Originally Posted by Ferrous Head View Post
And do they have hydraulic clutches or do you have to have arms like Popeye The Sailor Man ?
I believe they abandoned the clutch cable along with the bevel drive. My '93 has a hydraulic clutch. It is, literally, a "two finger" clutch. For me anyway, but I've ridden my Ironhead for 42 years, so my left forearm is about the size of my right thigh...
Yeah, I bet you're right. Like Harley's decision to go to the "quiet chain" on the Twinkie so they could reassign their allotted db's to the exhaust. It sucks when greenies make engineering decisions for you...
I do love the puzzled looks I get at stoplights, and the occasional "is something wrong with that thing?"...
mikethebike61's Avatar
I think the Sportster is the only street bike left using a cable...
I could be wrong
i'll ask the wife
She ALWAYS knows when I'm wrong
Remember the FORD fiasco about automatics coming our of park.....
Kid in a truck
Parked on a hil by a lake
Left there alone
Engine running
Parking brake not set
Truck finds reverse, goes into lake and kid dies
Somehow it's FORD's fault
But prior to around 1963 all autos read P N D L R
Then the safety NAZI's decided you should put R next to P to prevent the kid in the front seat from dropping the shift lever in R as you drove 65 mph down interstate and crash your car
Never mind all the engineers demonstrated that could not happen...good old BIG BROTHER in DC did it anyway....
Key word DRAGBIKE
Race bike/cars are not the same as street bikes/cars
I never had to R&R a wet clutch because a seal leaked
Call your local BMW shop and ask what it cost to R&R the clutch on one of their single dry plate units when a $7 rear main seal fails.
R-1100/1150
K-1200
It's north of $3000.00
They no longer use dry units....not even on their 200+ mph RR-1000.....if that beast does not need a dry unit....a Sporty damn sure doesn't
Blind Owl
Now, I could be wrong on this, but, doesn't the BMW have a single plate clutch ? A diaphragm clutch I'm thinking. But maybe springs.
And a hydraulic actuator ?
So, if Harley added a clutch from GM to fit a 350 Chevy with a hydraulic actuator problem solved. ?
(Oh, they may need to find room in the cases for a 14 inch plate. Maybe turn the engine sideways 90 degrees ? run a shaft drive ?)
Blind Owl
I'm not afraid of "complicated" things. Spent 40 years working on computers. Big ones.
So, sensors feeding engine management units and software determining ride handling and braking don' scare me.
Except they do.
We have computers on all of our modern vehicles and for the most part they work fine.
But experienced qualified mechanics are no longer working on them. We teach 20 year olds how to plug a diagnostic tool into them and then replace whichever module reports a problem.
I CANNOT begin to work on my own car anymore.
It's not economical in any case. But that whole thing about learning how things really work ? We no longer teach kids that.
They get new bikes with a games package that lights up like a Christmas Tree when you turn the key. (Or just get near them now ?)
It was a lot easier for me to survive the first few years of my life on bikes that put out less than 40 hp. I saw how many kids got maimed and killed when the first Honda 4's came out. And we sold them to 18 year old kids.
Steve9's Avatar
Steve9 Steve9 is online now
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
The yam RD's were the kid-killers when I was teens. Ported, chambers, damn little rockets
And our old Dodge had the push-button trans-a-mission
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertrap 2/2
