Battery
Last Post: oldboy
Keep & Kill
2 Weeks Ago
Senior Master Bike Builder
Posts: 2,199 Sportster/Buell Model: XLH bobber Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1974 Other Motorcycle Model: 883 Iron Other Motorcycle Year: 2010
Question about sprocket shaft bearing design
Something I'm not understanding. What makes the dual Timken stronger than the flathead style needle rollers? I understand the double opposing Timken handles thrust loads better, but there really shouldn't be that much thrust load in the flywheel assembly should there? Do they handle high bearing speed better? If so, why aren't all the bearings in the engine and trans tapered rollers? I'm just not understanding how changing to the Timken in my project adds any strength to the assembly. Thoughts?
2 Weeks Ago
Posts: 2,993 Sportster/Buell Model: KHK Sportster/Buell Year: 1954 Sportster/Buell Model #2: IronHead XLH Sportster/Buell Year #2: 1978 Other Motorcycle Model: XLRTT Other Motorcycle Year: 1966
Hi Bobber58,
The Timken is not there to handle side trusts, it is there for quicker factory assembly since the crank end play can be done at the Timken factory rather than opening and closing the cases several times while inserting the right amount of end shims in the HD factory...
Nevertheless, it is much stronger than any other bearing at the cost of more friction.
Don't know why people feel they have to change it, I have never had to replace one in 40 years of Sportsters ownership...
Patrick
Flat Head Forever
2 Weeks Ago
I had to replace one. I pulled this down off the wall of shame.
This is what happens when you assemble a double timken WITHOUT the spacer!
It split the outer race and spun the race in the cases, had to send the cases out and get the insert in the left case replaced to fix it.
2 Weeks Ago
Posts: 2,275 Sportster/Buell Model: Xlh Sportster/Buell Year: 1959 Sportster/Buell Model #2: Sprint 350 Sportster/Buell Year #2: 1969 Other Motorcycle Model: Guzzi Ambassador Other Motorcycle Year: 1969
I think you are referring to a big twin conversion.
Long story short
Double row sprocket bearings as used in pre-54 big twins do not handle long strokes or sustained high speeds very well.
It's not about strength, it's about flex.
Just google broken panhead cases and note almost all are pre-54 and many split right through the vin pad
2 Weeks Ago
You mean I can't shift my 5" stroke Pan at 7500rpm?
2 Weeks Ago
Posts: 2,314 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Sure you can. Shift from inside to outside the cases!
1 Week Ago
This is actually for my stick stroke Magnum motor. Trying to figure out if if really necessary to change to a Timken.
1 Week Ago
Posts: 2,260 Sportster/Buell Model: dragbike Sportster/Buell Year: 1960
It's only necessary if you want it to live.
1 Week Ago
+1000
If (and I mean "if") you actually want to run the double row in a magnum, open the mains clearance towards .002.
To quote someone much wiser than me:
That kind of bearing isn’t tolerant of crankshaft flex.
When the wheel assm flexes (it will)the bearing needs to have enuff clearance so bearing don’t "jam".
If the bearing does jam it takes the outer race for the ride too. That means the ccase flexes, and cracks.
You are seriously overpowering a 45 by turning it into a magnum . . . so take that into account.
1 Week Ago
Blind Owl
Posts: 6,303 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
Norton went to "Superblends" to help with the problem.
The smart Norton guys have billit cranks and the Superblends.
(But then Norton cranks make cooked Spaghetti jealous with their flexibility)
