Keep & Kill
6 Days Ago
Posts: 546 Sportster/Buell Model: XLCH Sportster/Buell Year: 1972
rear hub bearing change
I put new bearings in my rear hub some time back, but now that I think about it, they kind of slipped in easy with finger pressure for the most part.
Is this all right, should I take them out and raise some nubs with punch, should I get a new hub, or what?
6 Days Ago
MetalWorkingXLFan
Posts: 555 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: KHK Sportster/Buell Year #2: 1954 Other Motorcycle Model: Valkyrie Other Motorcycle Year: 97
My ‘76 rear hub was the same way. Very easy in and out with the bearings on both sides.
Good fit with no shake but not a press fit.
I was kind of shocked when I went to cast wheels with Timkens and found out how much interference fit they had.
6 Days Ago
Posts: 14,267 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
i remember hearing about that from the machinist i used when i did overhead crane service.
6 Days Ago
Posts: 11,882 Sportster/Buell Model: 1200R Sportster/Buell Year: 2005 Other Motorcycle Model: 5 bikes and 1 quad
I would, and you can also use the bearing lock material (it's like locktite for bearings). I used it for a crank main bearing on a RM125 many years ago. It held for a long time, but eventually the heat got to it. When it would fail, you could see the magnito moving in and out as the bike ran. I did also stake it like you mention and that is a great idea too. I don't think the hub will get as hot as the crank bearing did, so I think it will help you.
6 Days Ago
Posts: 2,287 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Stippling.
5 Days Ago
Duh I didn't even think of Loctite (680 I think) and I happen to have a bottle I used on my fork stem bearings.
5 Days Ago
Posts: 3,008 Sportster/Buell Model: xlh 1000 69 79 xlch Sportster/Buell Year: 1977 Sportster/Buell Model #2: 80 FXE 82FLH 83FXR Other Motorcycle Model: 78FLH 79xlch 96xl 79xlh
I remember changing them in the 70s on low mile bikes, they were a slip fit from the factory, just a light tap had them in and out.
