Last Post: ronccc
0 OEM Headlight Bucket?
0 Year help on ironhead confused
0 Removing Rear Shock
Last Post: slamtry
0 keihn setup at Altitude
0 Boardtracker Project
Last Post: Ultrarunner
0 New from Ohio
0 Missippi Gulf Coast here.
0 Identity crisis
0 Pinion shaft roller bearing plug fit
Last Post: xraytoken
0 Fork Oil Measurement
Last Post: Cyclone14
Last Post: Desertfox
0 NRA files for bankrupcy
0 Who runs (or has run) a Barnett Scorpion Clutch?
Last Post: Scott
0 Newbie seeks smoother ride
Last Post: 45Brit
0 Carb Air Vent hole cracked
0 63 XLCH revival
0 My Wife Says …
0 Handlebars
Last Post: Dr3wDrop
0 Please School Me On Carbonite Clutches
0 mississippi queen video
0 motorcycle on lift for two+ years
Last Post: Akdawg
0 my sunday driver...
Last Post: 84rzv500r
0 Rebuild a 2 stroke in 9 minutes :)
steve yorke (63), edman (55), Hudsonator (53), kozman32 (53), R3DN3X (51), gmcsid (50), mitch (45), Txngrg87 (34), Gotenfan (31)
Old 5 Days Ago
Deimus Deimus is offline
Master Bike Builder
Microwaves heat by exciting water molecules thus generating heat. So unless that bearing has a lot of water, that video is a hoax.
https://www.youtube.com/watch?v=kp33ZprO0Ck
If this presenter is too difficult to watch, you can jump ahead to time index about a minute and forty seconds.
Old 5 Days Ago
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Maybe you should watch the video the OP linked. In particular, the part about wrapping the bearing in WET paper towels.
Old 5 Days Ago
Master Bike Builder
You're right, I only watched the beginning of the video.
Old 5 Days Ago
Water isn't the only thing affected by m-waves. Point in case: that thin metallic layer in your pot pie box, that gets super-hot and browns the food trapped against the metal. Tasty!
Melting metals and heat treating are also possible: https://www.industrialheating.com/ar...rowave-heating
Ham, porkchops and bacon all come from the same magical animal?! That's crazy!
Old 5 Days Ago
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of light
I had a thought I have a nuwave counter top inductive unit works great with the right pans
If the bears were big enough it might with for bearings my inductive bearing heater was about $1,800.00 the counter top inductive cooker was under 200 it browns a steak real nice
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
Old 5 Days Ago
my microwave's been paid off since day one.
