1 Week Ago
Posts: 35 Sportster/Buell Model: sportster xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 73 Other Motorcycle Model: sportster Other Motorcycle Year: 2003
1970 sportster overload
I need to know the stock mounting location of the overload breaker on the 1970 Sportster. The factory breaker has 2 wires and a 2 hole bracket attached.
Any help will be appreciated.
1 Week Ago
Posts: 5,938 Sportster/Buell Model: XLH Sportster/Buell Year: 72
probably just under the seat
1 Week Ago
The coil is mounted under the seat.The part#74589-67a.The 2 mounting holes are 3/16 and 1 1/2 inches on center.Bracket overall length is 2 inches and 3/8 inches wide. This style was factory installed from 67 to 72. Any thoughts?
1 Week Ago
Posts: 846 Sportster/Buell Model: xlch Sportster/Buell Year: 1971 Sportster/Buell Model #2: xlh Sportster/Buell Year #2: 1974 Other Motorcycle Model: xl1200cp Other Motorcycle Year: 2011
How 'bout the underside of the battery carrier ? Here's a pic from my '71 xlch. I imagine a '70 xlch is similar.
If this doesn't align with the parts you have in hand, then you'll need a '70 owner/expert to weigh in.
1 Week Ago
Doc thank you for the pic.Is your 71 stock?I have a 70 xlch that I am adding electric start.
I will check my battery boxes for a bracket and if not will add one. Thank you
1 Week Ago
Originally Posted by sungod
Is your 71 stock?
Pretty close for a '71 xlch
I can't attest to the location of the circuit breaker for a '70 XLH though. The XLH battery carrier/box is different (from an XLCH). You really should have a '70 XLH knowledgeable guy confirm the location...... before you proceed too far.
1 Week Ago
Yes I will investigate more info for the xlh conversion.I just checked my xlch battery tray and you are correct the bracket is there.PS your 71 is beautiful.Thank you
1 Week Ago
Posts: 1,669 Sportster/Buell Model: XL Sportster/Buell Year: 1992 Sportster/Buell Model #2: 1978 XLCH project Other Motorcycle Model: Sportster XLH Other Motorcycle Year: 1975
That purple bike is rather gorgeous. I suppose the paint is called “Plum Crazy” or some such 1970s name?
1 Week Ago
Posts: 6 Sportster/Buell Model: xlch Sportster/Buell Year: 1972 Sportster/Buell Model #2: xlh Sportster/Buell Year #2: 1977
sparkling burgundy...bought a 72 fx new in that color.
1 Week Ago
Posts: 248 Sportster/Buell Model: XLH Sportster/Buell Year: 1967 Other Motorcycle Model: FLHR Other Motorcycle Year: 2019
On my 67 XLH the circuit breaker is attached to the back side of the battery box with two small screws between the box and frame rail. Hopefully this makes sense
