Keep & Kill
4 Days Ago
Posts: 4 Sportster/Buell Model: XLH 900 Sportster/Buell Year: 1971
Front brake light switch/handlebar control 1971
Hello All,
I'm in the reassembly phase of my front end rebuild. I've done the fork seals, and steering head bearings. I have new wheel bearings and front brake shoes. I've sorted the wiring on the fork terminal bar and repainted the headlight bucket. (Would like to upgrade to an LED but need to do some research on that)
My question is about a wire I have that is listed on the SM diagram as a front brake light switch. (if I remember correctly it's a red wire from the bundle that is joined to a gray wire going from the front brake lever and connecting to the #5 spot on the terminal) I see on the break lever an opening where I think it would go but I don't see anything in the parts book about the actual switch itself. Also it looks like the wire was external on the handlebars while everything else was run internal. Was this some kind of add on or accessory? I really like the idea of the function but don't want one ugly gray wire zip tied to the handlebar.
Any thoughts or ideas?
Thanks
Matthew
1971 Harley Davidson Sportster XLH
1972 Honda CB350
1989 Yamaha TW200
2008 Suzuki Vstrom 650
4 Days Ago
Posts: 845 Sportster/Buell Model: xlch Sportster/Buell Year: 1971 Sportster/Buell Model #2: xlh Sportster/Buell Year #2: 1974 Other Motorcycle Model: xl1200cp Other Motorcycle Year: 2011
It's in the parts book...... look up p/n 71900-70
The switch screws into the front brake lever & the 2 wires run external to the handle bar (aka zip tied to the handle bar). That's the way it was done in 1971.
4 Days Ago
Posts: 11,031 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
My buckhorn handlebars have holes to run the brake switch wire into them at the hand controls and out between the riser clamps and that's the way I have my wires run on both sides. If yours don't have them you can always add the holes yourself.
4 Days Ago
Posts: 670 Sportster/Buell Model: XLCH Sportster/Buell Year: 1971 Sportster/Buell Model #2: 1973 HD/Aermacchi TX125 Other Motorcycle Model: 1988 BMW K75
My '71 doesn't have the front switch but I see the hole where it should be. I just considered it unnecessary. With drums the front and rear brakes are needed simultaneously for effective braking.
4 Days Ago
Posts: 1,646 Sportster/Buell Model: XL Sportster/Buell Year: 1992 Sportster/Buell Model #2: 1978 XLCH project Other Motorcycle Model: Sportster XLH Other Motorcycle Year: 1975
I don’t know about Sportster drum brakes, but certainly it was nothing unusual to have no front brake light on British drum brake bikes, or Japanese ones for that matter
3 Days Ago
Posts: 32,520 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
The switch is not related to effective braking? Just operates the light!
3 Days Ago
Posts: 252 Sportster/Buell Model: XLCH Sportster/Buell Year: 1971
In Pennsylvania it would be needed to pass inspection.
3 Days Ago
My point exactly. 😉 With drum brakes you can't stop effectively wiithout both front and rear applied simultaneously which means the brake light is on with only a switch on the rear linkage.
