Keep & Kill
3 Days Ago
Posts: 50 Sportster/Buell Model: 883 low Sportster/Buell Year: 2006
Pinion shaft roller bearing plug fit
Hey guys!
So, while Im waiting for my transmission parts to arrive I´ve been checking other stuff from the bottom end.. When I took apart the engine the pinion shaft rollers looked okay, they weren´t worn, burned or damage.
But there was a lot of stuff put together the wrong way in this bike so I would like to check if the roller size is the correct one.
Searching arround the forum I found a thread that gives a formula to determine the plug fit instead of buying different size rollers and trying them on. Does anybody know if is this is right? I have attached a link with a picture of the thread Im talking about.
Also, when I pulled out the transmission instead of having rollers in the mainshaft like the ones in the manual, it had a needel roller bearing (Maybe its an upgrade from the old rollers?) I was thinking on buying the oem rollers and I was wondering if I could use the same formula as the one used to determine plug fit in the pinion shaft rollers.
Does anybody know if there is another manufacturer besides jims that makes a cheaper sprocket shaft Timken bearing assembling tool or somebody has a used one for sale? The price for the jims one in Europe its 200€....
thanks in advance, you guys are really helping me out with this build.
https://postimg.cc/wyMGYsp8
3 Days Ago
Posts: 32,520 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
Originally Posted by Jaime1840
Nothing "technical" in this link?
3 Days Ago
What do you mean? English is not my mother language, I might be missing something.
3 Days Ago
Posts: 5,452 Sportster/Buell Model: XLCH Sportster/Buell Year: 1962
Ham, porkchops and bacon all come from the same magical animal?! That's crazy!
3 Days Ago
Blind Owl
Posts: 6,295 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
I presume here your talking about the right side case bearing ?
It is not common but some people replace that bearing, usually with a ball bearing.
The case has to be machines to make the fit though. To go back to the original set up now might require a lot more work.
If it's set up to use a captured roller bearing there I would stick with that. Most likely a metric one and easy enough for you to find.
3 Days Ago
What year cases?
I think 84 & 85 had a needle bearing
3 Days Ago
Sorry. What I see in the link is no picture of the parts you were discussing, only some advertisements, some of which I would not show my children
3 Days Ago
OP has posted elsewhere about a '74...
2 Days Ago
Originally Posted by GA_Ironhead
Thanks
2 Days Ago
Hey Ferrous Head,
Yes, Im talking about the right side case roller bearings.
It looks like the race has been replace but I dont know if the case has been machined, Im just worried because I havent seen anybody running a bearing like this and I tought it might be wrong, I just found a picture of it. I have attached a picture below.
https://i.postimg.cc/yNYbQqbB/gbxbearing.jpg
thanks
