0 71 XLH Value?
Last Post: jeffro57
0 No start after ultima ignition, thoughts?
0 Evo sportster Ignition Modules
Last Post: 83XLX
0 Allegheny National Park III
0 60’s XLCH front tyre
Last Post: 83XLX
0 Tuning a keihin butterfly
Last Post: 83XLX
Last Post: dtwaddell42
0 72 ih stroker advise needed
Last Post: DR DICK
0 F/S 1991 883 Ignition Module
Last Post: Edster
Last Post: The Doctor71
0 Hello from CT
Last Post: fafcpa
Last Post: Andy56
0 NOS cases
Old 16th October 2021
dtom4 dtom4 is offline
Sportster/Buell Model: 883L
dtom4 is an unknown quantity at this point
Default 09 883L starts but dies, new fuel pump
Picked up an 2009 883L with 4K miles last year. Wouldn't start after the winter.
Just got around to playing with it now and turns out the fuel pump was shot. Replaced it with an All Balls unit and a new battery and it fires up but won't stay running for more than a second or two. I've checked the wiring and everything seems fine. I also replaced the quick dissconnect lower oring and the little one in the fuel line(had to use one from a Harbor Frieght assortment pack which wasn't the exact size but it worked) because of a leak. Did some research and seems some suggests replacing the crank position sensor.
Don't really want to be throwing parts at it and figured maybe I could tap into the vast knowledge base here for some advise. I'm a newbie to Harley's and relatively new to riding. Any input would be appreciated. TIA.
Dave
2009 883L
4K miles
motorfish's Avatar
motorfish motorfish is offline
Sportster/Buell Year: 2012
Other Motorcycle Model: Road Glide CVO
Other Motorcycle Year: 2009
motorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond reputemotorfish has a reputation beyond repute
This may sound stupid, but worth checking out...Pull up jiffy stand before starting her up.
My friend's Softail was doing exactly this, all because of the stand sensor "thinking" the bike was in gear.
Other than that, does the fuel actually reach past the injectors? they might get gunked up and not spraying enough fuel. Easy check - start her, and when she quits, take out spark plug(s) to see if they are wet.
On replacing the O-rings, if the replacement little one was not the right size, it could well prevent the spring/pin being pressed deep enough to let the fuel pass into fuel hose/injectors.
Old 17th October 2021
Check your Diagnostic Trouble Codes:
http://sportsterpedia.com/doku.php/t...k:ref:genmsr08
You might also check the Password Learn Procedure:
http://sportsterpedia.com/doku.php/t...:evo:trouble01
For Sportster Tech Info:
