0 Evo sportster Ignition Modules
Last Post: Stojan85
Last Post: sevenyears of famine
Last Post: JimVonBaden
0 71 XLH Value?
Last Post: jeffro57
0 No start after ultima ignition, thoughts?
Last Post: 83XLX
0 Allegheny National Park III
0 60’s XLCH front tyre
Last Post: 83XLX
0 Tuning a keihin butterfly
Last Post: 83XLX
Last Post: dtwaddell42
0 72 ih stroker advise needed
Last Post: DR DICK
0 F/S 1991 883 Ignition Module
Last Post: Edster
Last Post: The Doctor71
0 Hello from CT
Last Post: fafcpa
Last Post: Andy56
0 NOS cases
1979 oil issue, no oil, no oil rear rocker
Old 21st October 2021
Hardtail28 Hardtail28 is offline
Sportster/Buell Model: Sportster 1000xlh
Sportster/Buell Year: 1979
Other Motorcycle Model: 1975 cb750
Hardtail28 is an unknown quantity at this point
Default oil to front rocker, no oil to rear?
hello friends, my name is hardtail28. i have a 1979 1000xlh sport and seem to be getting oil to front rocker but no oil to rear. my bike works on a gearoter/scavenger system and by all logical dictations, should supply oil to both rockers if oil is being supplied to either one. i took off the oil supply line from the "split-case" front (on rear rocker) that leads to the other split case on the same rear rocker (2 cases per each rocker, 4 in all) and road down the street for a min. but, not a drop. i can't think of any other cause than a clogged line? although, I did read something about a tight rocker arm possibly may also be a suspect? the post went on to say, loosen the nut on the rocker arm shaft, run the bike and if oil produces.. the tight rocker arm can be assumed, was to blame. is this a fact-based conclusion?
