0 WTF Happened
0 Flame's New 1989
0 german student throws puppy at hells angel then flees on bulldozer
Last Post: Aion
0 My 1250 to 1275 build
Last Post: seajay
14 Intro
Last Post: Aion
0 HSR42 on a 90" ?
Last Post: frogg_nutts
Last Post: 201648Rider
0 Ironhead questions
Last Post: Chicken-hawk
Last Post: Merch131ho
Last Post: Four Speed
0 Mikuni HS40 flatslide
Last Post: Vohnsen
Last Post: Johnmotoguy
Last Post: jharback
0 started her in gear
0 super b overflow
0 Falling out of 1st
Last Post: joes95bobber
2 Humble pie
Last Post: Sprtstr1200s
Old 9th January 2019
htown16 htown16 is offline
Sportster/Buell Model: R1200
Other Motorcycle Model: Triumph,Norton,BSA
htown16 is an unknown quantity at this point
Just how in the heck do you get a wrench on the nut holding the negative cable end on the stud on the crankcase? I couldn't a socket past the wiring harness over the top of it and there was no room for an open or box end wrench. I ended up pulling the rear belt cover off and coming at it from under the belt with a box end wrench. The rear belt cover was a bitch to get off because the brake rod blocked the lower bolt and almost wouldn't let the cover come loose. Harley says you should undo this end of the cable every time you pull the battery. Yeah, right!
spitfirechopper's Avatar
spitfirechopper spitfirechopper is offline
Sportster/Buell Model: ironhead xlx
Sportster/Buell Year: 1983
Sportster/Buell Year #2: 2005
spitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud of
i just take the sprocket cover off and use an open end spanner
rejeanprimeau's Avatar
A swivel head key. It's the only 7/16 key I own with a swivel head.
XL Ed's Avatar
XL Ed XL Ed is online now
I moved mine to the through stud and nut on top of the primary.
BKB's Avatar
BKB BKB is online now
Yeah, what Ed said. Run the cable across the top of the battery, down & out the bottom of the cover, to the stud on the primary case that has the other ground wires on it. Much easier to get to & you can pull the battery out a lot easier, too.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
got any pictures?
Originally Posted by spitfirechopper View Post
got any pictures?
Here's the Sportsterpedia section on Ground Checks:
http://sportsterpedia.com/doku.php/techtalk:evo:elec01
Check Out The Sportsterpedia
wedge's Avatar
wedge wedge is offline
Exactly, and the added benefit is that the ground is now on the left half of the case, which means it is more directly connected to the starter. The starter draws the most current on the bike, so eliminating that case seam will ensure you don't have any voltage drop from the seam.
Note: I use 4 ga. and solder the lugs on. as mentioned, don't overheat any solder joint. Use a torch on the lug like soldering a pipe. Get it hot fast, get the solder in, and get the heat off quickly. Otherwise, the heat will move down the cable and pull the solder with it.
On the ground cable, the ends get corroded inside the strands at the lug. For that reason I never heat shrink the ends of ground cables to allow them to dry out rather than collect moisture under the shrink.
Old 11th January 2019
Sportster/Buell Year: '59
Other Motorcycle Model: 2004 XL883 '57 Tribute
PetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud of
The factory has the battery in backwards. You should always attach the ground cable last, which cannot be done the way it was original built. SMH
Pete's Ponies Mustang RUSToration & Performance
Old 12th January 2019
Air-Cooled Forever
Originally Posted by PetesPonies View Post
The factory has the battery in backwards. You should always attach the ground cable last, which cannot be done that was it was original built. SMH
Ain't that the truth! In my owner's manual it says to unhook the Neg. cable from the crankcase stud. Then it says to disconnect the Pos. and remove the battery w/ Neg. cable attached. Trying to get that Neg. cable up and thru that tiny little area, is quite a chore.
