0 WTF Happened
0 Flame's New 1989
0 german student throws puppy at hells angel then flees on bulldozer
Last Post: Aion
0 My 1250 to 1275 build
Last Post: seajay
14 Intro
Last Post: Aion
0 HSR42 on a 90" ?
Last Post: frogg_nutts
Last Post: 201648Rider
0 Ironhead questions
Last Post: Chicken-hawk
Last Post: Merch131ho
Last Post: Four Speed
0 Mikuni HS40 flatslide
Last Post: Vohnsen
Last Post: Johnmotoguy
Last Post: jharback
0 started her in gear
0 super b overflow
0 Falling out of 1st
Last Post: joes95bobber
2 Humble pie
Last Post: Sprtstr1200s
  #1341
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Originally Posted by Vohnsen View Post
Daym my bike is 396 lbs
The Sportster frame must be heavy
Sendt fra min EML-L29 med Tapatalk
My opinion is that they are not very heavy. I'm at 405lb, drop the defender pipe for cycle shack m pipes that i have and I'm sub 390. A handful of bikes in amra are sub 400 with stock frames.
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
If I remove the stock tank I’m right around the same weight as well. Remove the defender and I’d be sub 400 too. Soon...
this isn't just a trend homie, it's a lifestyle...
madnss's Avatar
Heck ya, the 3.3 tanks and fuel are heavy. So are canoes though
madnss's Avatar
Originally Posted by cycowrencher View Post
Weighed the bike... 490lbs
Sent from my LG-LS993 using Tapatalk
Say what?????!!!!!!
Weld a big chain to it and use it as a ship anchor
cycowrencher's Avatar
Aint got all them big dolla parts... It was 535 last season...
Tinz's Avatar
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond repute
Really need to weigh my bike this year. Should be 375 ish. This tank is 1.5lbs before paint .
That’d be sweet
madnss's Avatar
Right.....
A metric or Buell front end conversion, a metric or Buell rear wheel, a cheap aluminum tank with cheap fiber shell and you won’t even be close to stock weight.
