0 WTF Happened
0 Flame's New 1989
0 german student throws puppy at hells angel then flees on bulldozer
Last Post: Aion
0 My 1250 to 1275 build
Last Post: seajay
14 Intro
Last Post: Aion
0 HSR42 on a 90" ?
Last Post: frogg_nutts
Last Post: 201648Rider
0 Ironhead questions
Last Post: Chicken-hawk
Last Post: Merch131ho
Last Post: Four Speed
0 Mikuni HS40 flatslide
Last Post: Vohnsen
Last Post: Johnmotoguy
Last Post: jharback
0 started her in gear
0 super b overflow
0 Falling out of 1st
Last Post: joes95bobber
2 Humble pie
Last Post: Sprtstr1200s
electrical, wiring harness
  #1851
Old 6 Days Ago
tattooglisha tattooglisha is offline
Sportster/Buell Model: xl1200s
Sportster/Buell Model #2: XL1200S
Sportster/Buell Year #2: 1998
tattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to alltattooglisha is a name known to all
Original rear shocks have piggyback addition and they are adjustable. I have shorter 10 1/2" and they are progressive suspension but will bottom when with wife and u hit great hole . Take that motor and run it and keep it stock as long as possible , i changed alot of stuff but with this knowledge i wouldnt do it again. Stock sport model will give you small trouble . Just replace stock parts with dame new parts if necessary and youll be fine. It performs really good and gives alot for the buck . When you change one thing in engine you must do another too. Stock will.be reliable and fast with great mileage.
Old 1 Day Ago
steelworker's Avatar
Other Motorcycle Year: 2016
Originally Posted by tattooglisha View Post
Sorry I was writing from a fckn phone so i cant see it right. It looked to me like your nick name was ASWracig. Ok. P.s.I have a question. Its also stupid cause you can not know the answer without additional info but i will ask anyway maby you can point me from an experience.
I have worn pinion shaft OIL PUMP GEAR, one guy said you shoud check your crank and redo it. Well bike is xl1200sport 1998. Can it be just wear on that gear through time and crank shaft is spreading ?? Tnx. Anyone can answer pls.
The oil pump drive gear is known to wear. A bronze replacement gear is available.
Here's Hammer Dan explaining why...
https://www.youtube.com/watch?v=LanQHfNsso8
