0 Sportster Cobra seat
0 Ironhead in the uk
0 Glyptal?
0 TC88A update ?
Last Post: Yakcm2
0 1969 Sportster 50th Anniversary T-Shirts
Last Post: Magneto Sportster
0 lengthen master cylinder
Last Post: 11alan111
3 Shaky Dave Recovery
Last Post: a-sad-anorak
0 Mid West Meet & Greet
0 I'm almost afraid to ask this...
0 Too HOT to ride?
0 Idle / transfer ports Q
Last Post: Billy1200
Last Post: c1skout
0 Photo bucket
Last Post: duffy
Last Post: savagegarden
Reynoldston (79), showmebandit (66), Hoppy1313 (66), FredrikK (64), Toejam503 (64), YO MUDA (61), Altopass (60), tim 2007xl1200c (53), w9awx (47), 3xtrastout (41)
View Poll Results: which do you prefer?
Vance & Hines 142 48.30%
Screamin' Eagle Slash Cuts 55 18.71%
Get a 2-1 already... 85 28.91%
Who care's about HP, Get some LOUD Drags.. 19 6.46%
Multiple Choice Poll. Voters: 294. You may not vote on this poll
exhaust, v&h, vance and hines
Old 5th June 2008
ReddTigger's Avatar
Default Dyno Run, V&H straight shots vs. Screamin' Eagles
I posted this in the sticky, but I wanted to get some feedback as well as provide some information between the pipes.
Vance & Hines Straight Shots (Baffled with a lollipop)
Screamin' Eagle Slash Cut with Moddified Baffles (Holes cut out in baffles)
Screamin Eagle 1200 Heads 61cc 10° dome
.010 over 10° dome pistons
Screamin' Eagle 1200 Ignition.
Screamin' Eagle Air Box (original) with K&N filter
Stock Carb
Stock Cam
Stock Wires
States I've Ridden in
71.3 hp 70.8 tq
Old 5th June 2008
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
biknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to behold
I not that impressed with the bottom end below 3300 rpm. With stock cams and that high of compression it seems like it should be at least 5 hp more? My experience with SE slip ons was about the same. I lost bottom end too.
Completely stock except for, Branch #5 heads & 10.5:1 JE pistons, Red Shift V531 cams, S&S Super E, ThunderJet, V&H Sideshots, S&S Flywheels, Dyna 2000i, Stortz 55mm Inverted Fork, JMC Swingarm, Works Performance 12.5" Shocks, PM 4 Piston, PM wheels, 18 x 150 R tire, Custom Belt Drive Conversion, Still Has Original Nut Behind The Bars
Old 5th June 2008
wandrur's Avatar
wandrur wandrur is offline
Thx for the help, jackass
Sportster/Buell Model: N/A
Sportster/Buell Year: N/A
Other Motorcycle Model: FXDL Low Rider
Other Motorcycle Year: 2007
wandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond repute
I must say I like the torque of the V & H. But will a difference of 1-3 hp or ft/lbs really be that significant? I'd be making aesthetic decisions at this point, personally. Between those two, I like the look of the slash cuts over the straight shots. (You were wanted opinions like this, yes?)
"Assuming you know how I feel about the Constitution just makes you look stupid."
--Special Agent Megan Reeves, Numb3rs
Old 5th June 2008
biknut's Avatar
In a side by side roll on 3 hp looks huge.
From the choices allowed in this poll I vote for V&H because of looks, and the fact that they work pretty good. I don't like 2:1, I guess you all know that by now. Anyone that says HP doesn't matter is lying to themselves.
Old 5th June 2008
Hot Rod Sporty's Avatar
Hot Rod Sporty Hot Rod Sporty is offline
Hot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud of
Looks like you're runnin' just a bit lean. I wonder what would happen to those numbers if you shim the needle up one notch. I bet they'd improve a horse or 3...and improve the torque number...
________________________________________
PROUD MEMBER OF THE 'IGNORED BY '79' CLUB :banana __________________________________
RIP James "Mr. Jimi" Melton - 1947-2008
Godspeed brother.
"Dream as if you'll live forever. Live as if you'll die today." --James Dean
"A narcissist is someone better looking than you are." --Gore Vidal
"I just love the 'mechanicalness' of it"
--Indian Larry Desmedt
Old 5th June 2008
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
The AFR on the Graphs shows RICH, not Lean.
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 5th June 2008
You're right. My bad....
Old 5th June 2008
ReddTigger's Avatar
the bike was set a little rich, so that when I got down to sea level, it'll be right on the money.
Old 5th June 2008
ReddTigger's Avatar
I'm not worried about a 3 hp at the MAX of the scale. when I'll roll it on, it'll be just about the same. with a little more torque..
Torque gets you going,
HP keeps you going.
Old 6th June 2008
biknut's Avatar
HP keeps you going.
A lot of roll on's start at about 50-60 mph. I'm just saying it looks a little weak down there for stock cams and high compression. Maybe about 5 HP.
