0 **DK Custom- *NEW* Sportster Slip Stream Skid Plate-10% Introductory Savings**
Last Post: bplinson
0 Bob from Appleton WI
0 1990 Sportster. Something is pulling voltage from battery??
0 Primary fluid escapeing into crancase
0 Whats a bigger priority - FF or W/shield?
Last Post: khav
0 As far as maintenance goes...Cycle Electric or Alternator?
Last Post: ericfreeman
0 Best Tires to get 2017
Last Post: ReddTigger
0 How dangerous is 2k clear coat really?
Last Post: lugster
0 check my chain?
Last Post: Fridge
0 Shop Arson
Last Post: ss396
0 Lost compression?
Last Post: bimbo
3 Restored, original or near-stock Ironhead pictures
Last Post: khav
0 Screw Loose's Repairs
Last Post: cotton1
0 Oil Pump upgrade
Last Post: hotrodbiker
Last Post: jordan1200
Last Post: VaFish
0 New Hammer Impact Air Intake Powder Coated
Last Post: Outtakes
0 first change, very little oil
0 Who Runs Turn Signals?
Last Post: vagrant318
0 Free to a Good Home (pay $8 shipping only):2014 FSM, used
0 Removing powder coat?
Last Post: Oli1200
0 883 Sportster in Baja
Last Post: VaFish
stevervp, philvet (75), outlawreb (63), rabes56 (62), Bigmatt (60), Beaker666 (54), hippiemwc (54), wumm883c (52), 2wheeltodd (51), israel (46), XRWeasel (44), Stitch (41), Dekooy (35), Titaniumrust (35), Ameri-Deutsch (34)
Sadsack's Avatar
Sadsack Sadsack is offline
Sportster/Buell Model: Xlh
Sportster/Buell Model #2: FX
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 2014
Sadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to allSadsack is a name known to all
Originally Posted by Yochstein View Post
A heat gun and a lot of patience. It was easier than I thought it would be. The glass is held in by hot glue/silicone on 3 points of the frame. You can see the glue still attached to the frame. I gently applied heat at first so not to crack the glass. After several minutes going around the glass, I took a tiny flat head screwdriver and gently worked it into one edge and slowly pried around to get under the glass. As it loosened up with the heat, I was able to pull the glass right off. Be sure to have a rag down or leather gloves on because that glass is red hot and you don't want to risk breaking it.
I drilled a pilot hole in that broken stem and clamped down on the bracket to tighten everything up. Tonight I plan on heating up the glue and sticking the glass back on.
This is the trick I learned on Youtube. I should have made my own tutorial video.
I admire your tenacity, but just about every swap meet I've ever been to have these mirrors for cheap.
I've often run with the devil, but I've never made any deals....
Subscribing Biker
Toejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant future
I have one good one sitting in my toolbox (the right one I think). I talked to several people I know who've experienced the same problem. Most said "just get new mirrors, preferably with the screws on back". Vibration is just gonna kill any repairs you make.
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Originally Posted by sltm1 View Post
What size hammer did you use to "remove" the mirror LOL
7 lb one.
