Keep & Kill
2 Days Ago
Posts: 615 Sportster/Buell Model: X1 Sportster/Buell Year: 1999
Originally Posted by cycowrencher
At this kind of compression it wont matter much...
Sent from my LM-V405 using Tapatalk
Nice! Lol
1 Day Ago
Posts: 2,795 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 2003 Other Motorcycle Model: 1984 KX 125
There is a GRC crank service and Carrillo rods in my future... As well as Ti valves so I can spin 8500 plus.... I'll be setting the limiter at 7900 and the shift light at 7600...
1 Day Ago
Posts: 14,383 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
Ceramic top and teflon skirt.
you didn't mention the gas ports in this post. are they common with these pistons?
1 Day Ago
Posts: 7,431 Sportster/Buell Model: 883 Xl Sportster/Buell Year: 1992
Just curious, why the Ti valves if you are shifting at 7600?
1 Day Ago
I'm setting the light for 7600. I average about another 200rpm for the shift, and should be shifted at 78ish... The Ti valves will be next year so I can shift @ 8500...it should make power to there. I have SS valves in it now, and they are too heavy to shift that high. If I can get it to a dyno, I'm betting that when the limiter hits at 7900 the power will still be climbing with that compression and those cams... My engine guy went with some pretty hot triple valve springs just to get to 8k. He does a lot of work for Ryan T. , so Im trusting his judgment.
1 Day Ago
These are a set of custom CP bullet series pistons that were originally ordered by Rat Racing for a project in 2017. Those ports are in the oil ring for oil scraping. Gas ports are usually through the crown into the top of the upper ring land. I bought them to step up the power since the turbo and custom efi was going to be more than my budget... I may still go down that road later, but this was cheaper and easier...
1 Day Ago
Lets see your off season builds
Nice!! Gonna be in the 9’s soon!
Sent from THEE White House
12 Hours Ago
Im hoping on pass 4 of licensing...
11 Hours Ago
thanks cycowrencher.
