0 answer with a question game
0 stress killer
0 Wiring Diagram in autocad
Last Post: springcj1
0 Amputee Sporty Springer Trike Conversion
0 budget sportster rider
0 Rode today, 10 days post op.
Last Post: priell3
0 I can't drive forty-five
Last Post: spamer80
0 Air or Co2 shifters
Last Post: mac93
7 Rear fender interchangeablity.
0 headlight upgrade
Last Post: priell3
6 Calling all musicians
Last Post: Eddieblz
0 No power/No Start
0 Things to Ponder game
Last Post: Eddieblz
Last Post: Eddieblz
Last Post: Grumpy-Biker
0 My 1250 to 1275 build
Last Post: Yochstein
0 Hello bikers from Southern Indiana!
1 2019 Iron 883 Drag Bars
spoke lacing wheels
Old 6th December 2018
sportsterdoc's Avatar
Originally Posted by TonyGall View Post
I never thought of the push/pull bit when I build a wheel !!!! I just build as standard and make sure all the spokes sound the same, here's one I did a few months ago.
Good use of dial indicator
TonyGall TonyGall is offline
TonyGall is an unknown quantity at this point
thank, I got it within 0.5mm runout on my home made jig it can be frustrating building a wheel and satisfying at the same time not something I do that often, but works out cheaper than buying a complete wheel.
Old 7th December 2018
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Have to indicate and basic balance. It's rotational mass eh? I tend to make the spokes sing less in dirt and choir on roads.
throw this bone out and see who bites? if you reverse rotation, do the so called push/pull reverse also?
all spokes are in tension to the rim counter-acting its opposite to adjust radius and and is pairs to adjust for lateral. by definition, they neither pull or push but become one. on a spoke mag, does one side on the spoke push and the other pull???
if you had pushing forces, would this not to cause nipple movement? now if the rim were to be loosely spoked, then the rim could flex and conceive-ably move the nipples, but if properly laced, the forces are balanced out. a spoked rim can flex a great amount, reason they do well in off road, but they flex as a unit, if not, broken spokes.
ive just bought a spoke wheel that came off a dyna for my sportster, the wheel will be rotating in the other direction and im sure it won't matter a jot as long as the spokes are tight.
hotrodbiker hotrodbiker is offline
Sportster/Buell Model: xl 883/1200
Sportster/Buell Year: 91
Other Motorcycle Model: ducati triumph enfield
hotrodbiker is an unknown quantity at this point
this may help ..https://www.youtube.com/watch?v=myxagLY_mDg
Official Wheel building vid .. I just did what they said on here !
