Keep & Kill
Corona Virus
26th August 2020
Posts: 831 Sportster/Buell Model: XL883-1200 Branch Build Sportster/Buell Year: 2000
How to stripped ignition sensor pickup screw
Tearing down engine to replace parts from seized pistons when got too hot, and come to take out bolt for ignition timing pickup rotor and not stripped complete, but how would one get this thing out. tried 5/16 and also metric but 5/16 was best fit.
But bolt doesn't seem to want to budge. Used heat, tried vise grips, but kinda slip of once turns, but what would ya'll suggest or what did you do if was in same situation to get this bolt off ? I have another pickup rotor from a new ignition from a while back, but the is a allen bolt, so can't get exact size except from when tried to get off with socket that fit in the first place.
Pretty sure it turns is righty tighty and lefty loosy.
Thanks for any feedback. Gonna spray some PB blaster on it... fingers crossed.
Bolt removal by groove meisterus, on Flickr
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
26th August 2020
Drill a small hole and use reverse screw extractor ?
28th August 2020
resolved with craftsman bolt extractor socket set from lowes, worked like a charm first time and no troubles
28th August 2020
Originally Posted by IXL2Relax
Don’t think it was rusted, just gunk from blue lock tight over the years I can only assume
