0 Ultima Ignition Issues
Last Post: cbolden2
0 One cylinder working ...
Last Post: Bert fegg
0 Fixing or replacing primary cover for a 1975 xlh?
Last Post: Jberg93
0 07 883 Low .... lifting
0 83 XLH w/Velorex 562
Last Post: Scott
0 Hard to find Neutral
Last Post: ThenCameHarry
0 WTB - 95 mid control shift arm
Last Post: bordens
Last Post: 45Brit
Last Post: Brad
0 0Salt Flat Sporton
Last Post: Magneto Sportster
0 2009 Iron 883 Wont Start!
0 Shady shifter shaft
Last Post: randy3934
0 Sidehack for XLS
Last Post: 11B40
0 too much oil in primary
Last Post: 73HEAD
0 Brad's 1995 883 Hugger
Last Post: Brad
0 1998 883 Clutch Disc
Last Post: gary59
4 Snow a week ago, now a Tornado Watch
Last Post: fafcpa
0 Rear shocks ?
2 WOW, This cracked? Wtf?
0 Do You Have Crash Bars/ Engine Guards?
Last Post: Azmarlin39a
GRAYFEATHER (71), vonriken (70), The Crusher (63), madisonlink (60), hillbilly (59), mardyk (56), Blade (54), dmraco (51), jmcclure (44), Ryand36330 (43), nrrs (43), CRB1006 (33), Yoitsjustin1 (21)
battery, ironhead
Old 30th May 2020
LetsDoIt LetsDoIt is offline
Sportster/Buell Year: 1979
LetsDoIt is an unknown quantity at this point
Default Battery ?
79 ironhead electric start only seems all the posts say different things, help
Old 30th May 2020
doodah man's Avatar
“All the posts say different things” about what exactly??
Old 30th May 2020
nothing really definitive, many suggestions on cca and the other battery specs but no actual brands or anything specific enough to make it easy
Old 30th May 2020
doodah man's Avatar
A lot of folks like the agm batteries for the no maintenance aspect but they cost you. Traditional lead-acid are certainly cheaper if you don’t mind keeping the cells topped off with distilled water. Check both your local Harley dealer and batteries plus store. As far as brands, I’m sure that almost all of them are made in china now so take your pick! Yuasa has been good for me, but currently I have whatever cheap lead-acid battery that is available from batteries plus. Being an xlch, my battery requirements are different/lower than yours.
Old 30th May 2020
brianbbs67's Avatar
Reformed Savant
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
I have had great luck with AGM. The Lead Acid seem to fail every year or 2.
Ok, now I'm revived
Old 30th May 2020
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
An AGM by Deka is my go to.....
Have a read thru this thread. Installed that battery in 2012 & it's still going strong. http://xlforum.net/forums/showthread.php?p=3276713
Check standard things like CCA, dimensions, & post alignment to ensure it fits your ride.
Old 30th May 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
The lead acid aren't even available in Australia anymore.
People just won't buy then.
Old 30th May 2020
An AGM battery won't leak acid all over your bike.
An AGM battery holds up to vibration better
An AGM battery will last 4+ years
There's 10 reasons to use a AGM bettery
Old 30th May 2020
Steve9's Avatar
Steve9 Steve9 is online now
Sportster/Buell Model #2: XL
Sportster/Buell Year #2: 1981
Other Motorcycle Model: FXDC
I really like my lithium/ion batteries.
Put one in my '13 FXDC and my '03 XL.
The battery I got for my sporty is over twelve lbs lighter than the lead/acid stock, and less than half the size. May also be mounted upside down, sideways-makes no difference.
Spins the high comp motor better than the lead it replaced.
It was about 80% more in cost is the only minus
Dimensions: 4.25" wide 4.25" tall 3.25" deep
Steve
'03 1250 stage two thunderstorm heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
Old 30th May 2020
60Gunner's Avatar
60Gunner 60Gunner is offline
Im not sold on the lithium technology being all that.
Check out Throttle X batteries. Best warranty on the market.
