2 Sloppy Throttle Feel
Last Post: XL_1200C
Last Post: Bryan1976
0 One cylinder working ...
0 Cali Carb 1989 883
0 New from Arizona
0 Chinese S&S carbs
0 too much oil in primary
Last Post: 73HEAD
0 2021 2nd. Annual Midwest M&G
0 Rear shocks ?
Last Post: Wiktor
0 Sportsters No More?
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: AXL.MODENA
0 Tire Pressure 1979 XLH
Last Post: 1Scooter
0 Ultima Ignition Issues
Last Post: 1Scooter
0 0Salt Flat Sporton
0 Hard to find Neutral
0 Can't clear unread messages
0 XLh 883 cylinder heads
Last Post: TomDelgado
0 New Dakota Digital speedo/tach...
0 RSD Front Pulley Cover Install?
Last Post: Dariusz
0 How many helmets?
Last Post: Marsikus
clutch, shift shaft
Old 15th June 2020
T_worth T_worth is offline
Sportster/Buell Year: 97
Default Bent shift shaft with play
I just took off my primary cover on my 97 xl1200S and discovered that I have a bent shift shaft. With further inspection, I noticed the entire shift shaft assembly has a lot of play and the plate from the assembly (34015-91) has been rubbing against the largest clutch sprocket.
Is it possible to replace the entire shift shaft assembly without removing the clutch sprocket and shifter retaining ring (11019)?
